Getting No Render after reinstalling java on computer
I have been using UMS for a while now and it has worked fairly well but I was having problems with my laptop unrelated to UMS and I ended up uninstalling Java and flash player and reinstalling them again.
Since doing that UMS can not find my PS3.
I have turned off my windows firewall. Im using a Asus RT-N56U router and have opened port 7001 on it for UMS to use.
I have uninstalled and reinstalled UMS version java 8 as that is what is on this computer now
I attached my logs in hopes someone can help me get this figured out agian.
Sorry for the newb problems but my google searches and attempts to repair this haven't been successful
- (20.44 KiB) Downloaded 231 times
Re: Getting No Render after reinstalling java on computer
So my problem was that with java 8 and Windows 10 I needed to go into the windows firewall and re-allow Java access.
Once I did that the PS3 showed up right away.
