Windows RT tablets support
i'm using a Asus Vivo Tab RT tablet with Windows RT OS. I have an app, called "Multimedia 8". It works with Windows Media Center, but not with UMS server. I even can't add UMS to the system(through devices section, pairing process). I even created a home group, but still no luck.
Please include the support of Windows RT OS to the roadmap
Re: Windows RT tablets support
Um why not just use Simple File sharing? Does windows rt not support all these files pretty easy?> also have u tried Different Applications?
I too would love a support for Windows/Surface RT's more limited codec support.
I made a donation to VLC, but that's only a partial solution.
Can someone recommend a vanilla renderer or one for another device, which might work on RT?
I use UMS to connect to my Xbox 360 and would love an RT counterpart.
John
John
