Marantz NA6005 render?
cnticws
Post by cnticws »
i just use Marantz NA6005 connect ums, play flac ok.
But it can NOT play dff file (from DSD). i plug usb, it can play well. and i have checked the manual, it says support DSD over DLNA or DSD transcode over DLNA.
so i just add an render file as Marantz-6005.conf, but it could not play dff yet.
i just upload the files. Please help me modify the Marantz-6005.conf
Thank you!
debug.log ums log file
Marantz-6005.conf i write the render file, but maybe not ok
view-source_192.168.1.16_8080_description.xml file on my Marantz NA6005 player
ip address
NAS (debian 7 x86_64 no monitor) 192.168.1.55
installed openjdk-7-jre headless and ums 5.2.2
Marantz-6005 player 192.168.1.16
my pc 192.168.1.22
na6005.zip
(14.09 KiB) Downloaded 506 times
Miklos
Re: Marantz NA6005 render?
Post by Miklos »
This sounds like the same problem I am encountering with the Marantz NA6005 & UMS.
squadjot
Post by squadjot »
@cnticws
Is the file extension .dss? If so, can't you just add them to the StreamExtensions = - list? (add ds2, aif and aiff too)
If you're trying to set the MimeTypesChanges, i think it should be:
MimeTypesChanges = audio/x-dff|audio/x-dsf=audio/x-flac
