For some reason subtitles won't display
victorterrero
Post by victorterrero »
I don't know but for the life of me i can't get subtitles for MKV's to display.
they work fine on the pc. but when trying to play them through the ps3 they won't show.
the subtitles are hardcoded by the way. anyway when i try playing them on the ps3 when trying to turn on the subtitles it comes up saying there are no subtitles present.
so i honestly don't know whats going on.
Thanks to anyone who can solve this problem.
squadjot
Re: For some reason subtitles won't display
Post by squadjot »
I think theres currently a bug, if you enable transcode folders, and in there select Mencoder [External subtitles/Undetermined] , does it work?
victorterrero
That worked. Awesome.
Thanks man.
Berzerk
Post by Berzerk »
Yeah, no subs here either.
They are just blindly copy/pasting crappy beta updates from PS3MS, don't even test them, and then release them as some "shiny new versions".
Berzerk wrote:They are just blindly copy/pasting crappy beta updates from PS3MS, don't even test them, and then release them as some "shiny new versions".
The opposite is true, we discard buggy updates from PMS.
