Ver 2.2.0 with some subtitles problems
microblue
Post by microblue »
I' have some subtitles problem when I finished ver 2.2.0 installation. When i watch a mkv file with srt subtitles, ums seems to slow both srt subtitles and embedded subtitles.
Then two subtitles mixed up on the screen.
It never happened with older version.
Is it a bug?
sabun
Re: Ver 2.2.0 with some subtitles problems
Post by sabun »
try to find something like this in renderer conf file (this is from Panasonic.conf)
CustomMencoderOptions=-vf softskip,expand=::::1:16\/9:4
and change this to
CustomMencoderOptions=-vf softskip,expand=:::::16\/9:4
The -vf expand code explained -
expand[=w:h:x:y:o:a:r]
Expands (not scales) movie resolution to the given value and places the unscaled original at coordinates x, y. Can be used for placing subtitles/OSD in the resulting black bands.
<w>,<h>
Expanded width,height (default: original width,height). Negative values for w and h are treated as offsets to the original size.
<x>,<y>
position of original image on the expanded image (default: center)
<o>
OSD/subtitle rendering
0: disable (default)
1: enable
<a>
Expands to fit an aspect instead of a resolution (default: 0).
<r>
Rounds up to make both width and height divisible by <r> (default: 1).
SuperDre
Post by SuperDre »
I have the same problem, never had this problem before.. PS3.conf doesn't have the line (it's completely empty), so this should be handled through the GUI itself. I Have 'ASS/SSA subtitle styling' unchecked, but 'fontconfig' and 'embedded style' checked.. For now I just remuxed the original subtiles out of the mkv, but that shouldn't be the solution.. So I hope this will be fixed in the next release (I'm using 2.2.1)..
Please post debug info :)
SuperDre
Post by SuperDre »
as requested, hope you can solve the problem.. I must admit, that I also tried Judge dredd before tai chi knowing that it had also embeded subtitles, but it seems it didn't have the problem, but tai chi hero does..
ums_dbg (double subtitles tai.chi.hero).zip
(11.63 KiB) Downloaded 988 times
SuperDre
Post by SuperDre »
SubJunk wrote:Is it fixed in this version?
http://www.spirton.com/uploads/UMS/UMS-SuperDre.exe
installing now, will try it later in the evening, will let you know as soon as possible, thanx ;)
SuperDre
Post by SuperDre »
I tried the newly supplied version and the subtitle problem seems to be fixed.
I tested it by installing this new version, went to a scene where I knew it had double subtitles, noticed it only showing the external subtitles, then installed 2.2.2, checked again, noticed the double subtitles, reinstalled superdre version again and checked again to see the external subtitles only again.. so it seems to be fixed..
thanx..
Thanks for confirming, the fix will be in the next version
