Subtitles work, but only a third is shown..?
Hi
I have just installed this great program. Everything runs smooth and is in sync - Great! BUT subtitles(only tried external) only work in a third of all the sentences.
For example, the first 3 lines in the movie subtitles work and everything, then it stops working for the next 5 lines, and then works again.
I have tried rebooting pc, uninstall or maybe it's something in settings, that needs to be changed..?
Can somebody please help?
Edit: I have tried streaming to both my PS4 and my Chromecast - same problem..
Re: Subtitles work, but only a third is shown..?
Tried a lot of videos. Found out that it's only danish subtitles that doesn't work. English subtitles works fine. Perhaps something to do with æøå in out language?
The easiest way is to post debug.log and attach also subtitles you used.
Then we can help.
viewtopic.php?f=9&t=556
Then we can help.
Same here with German language. iam sad
The subtitle file cannot be upldoaded but it works when i watch it on pc
- (61.07 KiB) Downloaded 568 times
even with the new 6 release, it dosnt work right.
any help?
any help?
Can you download the last build http://universalmediaserver-ci.hopto.or ... APSHOT.exe and try it?
It works!!!! Thank you so much =))valib wrote:Can you download the last build http://universalmediaserver-ci.hopto.or ... APSHOT.exe and try it?
