Sony KDL-40W5500 failing to play videos
Hi Guys,
First post but I work in IT so hopefully I can drop all the info required in.
I used to run PS3 media server a while ago and eventually found it had more and more issues. Anyway I upgraded to UMS a while ago and wasn't having any issues running the older versions. I saw there was an update and thought I'd deploy that for all the added goodies.
Alas my older Sony now fails to play videos. I get an error on the TV "Playback not available" and the logs have a few errors in them. So i'm hoping you guys can assist?
TRACE 2015-12-02 14:21:48.002 [New I/O worker #1] Sent to socket: Content-Type: text/xml; charset="utf-8"
TRACE 2015-12-02 14:21:48.002 [New I/O worker #1] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/5.3.1
TRACE 2015-12-02 14:21:48.002 [New I/O worker #1] Sent to socket: Content-Length: 2867
TRACE 2015-12-02 14:21:48.303 [New I/O worker #2] Opened request handler on socket /192.168.0.14:61952
TRACE 2015-12-02 14:21:48.303 [New I/O worker #2] Request: HTTP/1.1 : POST : upnp/control/content_directory
DEBUG 2015-12-02 14:21:48.303 [New I/O worker #2] Matched media renderer "BRAVIA KDL-40W5500 " based on address /192.168.0.14
TRACE 2015-12-02 14:21:48.303 [New I/O worker #2] Received on socket: X-AV-Physical-Unit-Info: pa="BRAVIA KDL-40W5500 ";
TRACE 2015-12-02 14:21:48.303 [New I/O worker #2] Received on socket: X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="BRAVIA KDL-40W5500 "; mv="1.7";
TRACE 2015-12-02 14:21:48.303 [New I/O worker #2] Received on socket: Host: 192.168.0.25:5001
TRACE 2015-12-02 14:21:48.303 [New I/O worker #2] Received on socket: User-Agent: UPnP/1.0 DLNADOC/1.50
TRACE 2015-12-02 14:21:48.303 [New I/O worker #2] Received on socket: Content-Length: 641
TRACE 2015-12-02 14:21:48.303 [New I/O worker #2] Received on socket: Content-Type: text/xml; charset="utf-8"
TRACE 2015-12-02 14:21:48.303 [New I/O worker #2] Received on socket: SOAPACTION: "urn:schemas-upnp-org:service:ContentDirectory:1#Browse"
TRACE 2015-12-02 14:21:48.303 [New I/O worker #2] HTTP User-Agent: UPnP/1.0 DLNADOC/1.50
TRACE 2015-12-02 14:21:48.303 [New I/O worker #2] Recognized media renderer: BRAVIA KDL-40W5500
TRACE 2015-12-02 14:21:48.304 [New I/O worker #2] HTTP: upnp/control/content_directory / 0-0
TRACE 2015-12-02 14:21:48.304 [New I/O worker #2] discover 109 refresh forced: true
TRACE 2015-12-02 14:21:48.304 [New I/O worker #2] End of analysis for H:\Downloads\Ubuntu\Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD[brassetv]
TRACE 2015-12-02 14:21:48.304 [New I/O worker #2] <?xml version="1.0" encoding="utf-8"?>
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<s:Body>
<u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1">
<Result><DIDL-Lite xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/"></DIDL-Lite></Result>
<NumberReturned>0</NumberReturned>
<TotalMatches>2</TotalMatches>
<UpdateID>1</UpdateID>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
TRACE 2015-12-02 14:21:48.304 [New I/O worker #2] Sent to socket: Content-Type: text/xml; charset="utf-8"
TRACE 2015-12-02 14:21:48.304 [New I/O worker #2] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/5.3.1
TRACE 2015-12-02 14:21:48.304 [New I/O worker #2] Sent to socket: Content-Length: 597
INFO 2015-12-02 14:21:49.772 [UPNPHelper] No IP filter specified, access granted to /192.168.0.151
TRACE 2015-12-02 14:21:49.772 [UPNPHelper] Receiving a M-SEARCH from [192.168.0.151:2048]
TRACE 2015-12-02 14:21:49.772 [UPNPHelper] Sending discovery [192.168.0.151:2048]: HTTP/1.1 200 OK<CRLF>CACHE-CONTROL: max-age=1200<CRLF>DATE: Wed, 02 Dec 2015 03:21:49 GMT<CRLF>LOCATION: http://192.168.0.25:5001/description/fetch<CRLF>SERVER: Windows_7-amd64-6.1, UPnP/1.0, UMS/5.3.1<CRLF>ST: upnp:rootdevice<CRLF>EXT: <CRLF>USN: uuid:8bdd00de-891c-4319-8163-4ccc9e9aecc6::upnp:rootdevice<CRLF>Content-Length: 0<CRLF><CRLF>
TRACE 2015-12-02 14:21:49.798 [New I/O worker #3] Opened request handler on socket /192.168.0.151:4447
TRACE 2015-12-02 14:21:49.799 [New I/O worker #3] Request: HTTP/1.1 : GET : description/fetch
TRACE 2015-12-02 14:21:49.799 [New I/O worker #3] Received on socket: Accept: */*
TRACE 2015-12-02 14:21:49.799 [New I/O worker #3] Received on socket: Host: 192.168.0.25:5001
TRACE 2015-12-02 14:21:49.799 [New I/O worker #3] Received on socket: Connection: close
DEBUG 2015-12-02 14:21:49.800 [New I/O worker #3] Reading MediaInfo: true (default: false)
DEBUG 2015-12-02 14:21:49.800 [New I/O worker #3] Adding status button for Unknown renderer
DEBUG 2015-12-02 14:21:49.815 [New I/O worker #3] Marking renderer "Unknown renderer" at /192.168.0.151 as unrecognized
TRACE 2015-12-02 14:21:49.815 [New I/O worker #3] Using default media renderer: Unknown renderer
TRACE 2015-12-02 14:21:49.815 [New I/O worker #3] HTTP: description/fetch / 0-0
TRACE 2015-12-02 14:21:49.816 [New I/O worker #3] Sent to socket: Content-Type: text/xml; charset="utf-8"
TRACE 2015-12-02 14:21:49.816 [New I/O worker #3] Sent to socket: Cache-Control: no-cache
TRACE 2015-12-02 14:21:49.816 [New I/O worker #3] Sent to socket: Expires: 0
TRACE 2015-12-02 14:21:49.816 [New I/O worker #3] Sent to socket: Accept-Ranges: bytes
TRACE 2015-12-02 14:21:49.816 [New I/O worker #3] Sent to socket: Connection: keep-alive
TRACE 2015-12-02 14:21:49.817 [New I/O worker #3] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/5.3.1
TRACE 2015-12-02 14:21:49.817 [New I/O worker #3] Sent to socket: Content-Length: 3035
TRACE 2015-12-02 14:21:51.975 [New I/O worker #4] Opened request handler on socket /192.168.0.14:61954
TRACE 2015-12-02 14:21:51.975 [New I/O worker #4] Request: HTTP/1.1 : HEAD : get/129/Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD.mkv_transcoded_to.mpg
DEBUG 2015-12-02 14:21:51.975 [New I/O worker #4] Matched media renderer "BRAVIA KDL-40W5500 " based on address /192.168.0.14
TRACE 2015-12-02 14:21:51.975 [New I/O worker #4] Received on socket: getcontentFeatures.dlna.org: 1
TRACE 2015-12-02 14:21:51.975 [New I/O worker #4] Received on socket: Pragma: getIfoFileURI.dlna.org
TRACE 2015-12-02 14:21:51.975 [New I/O worker #4] Received on socket: transferMode.dlna.org: Streaming
TRACE 2015-12-02 14:21:51.975 [New I/O worker #4] Received on socket: Host: 192.168.0.25:5001
TRACE 2015-12-02 14:21:51.975 [New I/O worker #4] Recognized media renderer: BRAVIA KDL-40W5500
TRACE 2015-12-02 14:21:51.975 [New I/O worker #4] HTTP: get/129/Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD.mkv_transcoded_to.mpg / 0-0
TRACE 2015-12-02 14:21:51.976 [New I/O worker #4] Asked stream chunk : TimeRange [start=null, end=null] of Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD.mkv and player FFmpeg
DEBUG 2015-12-02 14:21:51.976 [New I/O worker #4] Starting transcode/remux of Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD.mkv with media info: container: mkv, bitrate: 5523886, size: 1761261409, video tracks: 1, audio tracks: 1, video codec: h264, duration: 00:42:30.00, width: 1280, height: 720, frame rate: 23.976, mime type: video/x-matroska, attached fonts: false
Audio track id: 0, lang: und, audio codec: AC3, sample frequency:48000, number of channels: 6, bits per sample: 16
TRACE 2015-12-02 14:21:51.977 [New I/O worker #4] Looking for an audio track with lang: eng
TRACE 2015-12-02 14:21:51.984 [New I/O worker #4] Looking for an audio track with lang: fre
TRACE 2015-12-02 14:21:51.985 [New I/O worker #4] Looking for an audio track with lang: jpn
TRACE 2015-12-02 14:21:51.985 [New I/O worker #4] Looking for an audio track with lang: ger
TRACE 2015-12-02 14:21:51.985 [New I/O worker #4] Looking for an audio track with lang: und
TRACE 2015-12-02 14:21:51.985 [New I/O worker #4] Matched audio track: id: 0, lang: und, audio codec: AC3, sample frequency:48000, number of channels: 6, bits per sample: 16
TRACE 2015-12-02 14:21:51.986 [New I/O worker #4] Searching for a match for: und with eng and off
TRACE 2015-12-02 14:21:51.986 [New I/O worker #4] Searching for a match for: und with * and eng
TRACE 2015-12-02 14:21:51.986 [New I/O worker #4] Searching for a match for: und with * and und
TRACE 2015-12-02 14:21:51.987 [New I/O worker #4] Looking for a subtitle track with lang: eng
TRACE 2015-12-02 14:21:51.987 [New I/O worker #4] Looking for a subtitle track with lang: fre
TRACE 2015-12-02 14:21:51.987 [New I/O worker #4] Looking for a subtitle track with lang: jpn
TRACE 2015-12-02 14:21:51.987 [New I/O worker #4] Looking for a subtitle track with lang: ger
TRACE 2015-12-02 14:21:51.987 [New I/O worker #4] Looking for a subtitle track with lang: und
DEBUG 2015-12-02 14:21:51.987 [New I/O worker #4] Reading engines: "ffmpegvideo,mencoder,tsmuxer,avsffmpeg,avsmencoder,vlctranscoder,ffmpegaudio,tsmuxeraudio,ffmpegwebvideo,vlcwebvideo,vlcvideo,mencoderwebvideo,vlcaudio,ffmpegdvrmsremux,rawthumbs" (default: "ffmpegvideo,mencoder,tsmuxer,ffmpegaudio,tsmuxeraudio,ffmpegwebvideo,vlcwebvideo,vlcvideo,mencoderwebvideo,vlcaudio,ffmpegdvrmsremux,rawthumbs")
TRACE 2015-12-02 14:21:51.988 [New I/O worker #4] Using the video bitrate limit from the program settings (90)
TRACE 2015-12-02 14:21:51.988 [New I/O worker #4] Halving the video bitrate limit to 45000
DEBUG 2015-12-02 14:21:51.988 [New I/O worker #4] Reading DefaultVBVBufSize: true (default: false)
TRACE 2015-12-02 14:21:51.988 [New I/O worker #4] Adjusting the video bitrate limit to 44000 to make room for audio
DEBUG 2015-12-02 14:21:51.990 [New I/O worker #4] Creating pipe \\.\pipe\ffmpegvideo_61_1449026511989
DEBUG 2015-12-02 14:21:52.003 [New I/O worker #4] Caught exception
java.lang.IllegalArgumentException: Unrecognized calling convention: 3
at com.sun.jna.Native.invokePointer(Native Method) ~[ums.jar:5.3.1]
at com.sun.jna.Function.invokePointer(Function.java:477) ~[ums.jar:5.3.1]
at com.sun.jna.Function.invoke(Function.java:411) ~[ums.jar:5.3.1]
at com.sun.jna.Function.invoke(Function.java:323) ~[ums.jar:5.3.1]
at com.sun.jna.Library$Handler.invoke(Library.java:236) ~[ums.jar:5.3.1]
at com.sun.proxy.$Proxy2.CreateNamedPipeA(Unknown Source) ~[na:na]
at net.pms.io.WindowsNamedPipe.<init>(WindowsNamedPipe.java:166) ~[ums.jar:5.3.1]
at net.pms.io.PipeProcess.<init>(PipeProcess.java:60) [ums.jar:5.3.1]
at net.pms.io.PipeProcess.<init>(PipeProcess.java:67) [ums.jar:5.3.1]
at net.pms.encoders.FFMpegVideo.launchTranscode(FFMpegVideo.java:1032) [ums.jar:5.3.1]
at net.pms.dlna.DLNAResource.getInputStream(DLNAResource.java:2969) [ums.jar:5.3.1]
at net.pms.network.RequestV2.answer(RequestV2.java:374) [ums.jar:5.3.1]
at net.pms.network.RequestHandlerV2.writeResponse(RequestHandlerV2.java:300) [ums.jar:5.3.1]
at net.pms.network.RequestHandlerV2.messageReceived(RequestHandlerV2.java:256) [ums.jar:5.3.1]
at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) [ums.jar:5.3.1]
at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [ums.jar:5.3.1]
at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [ums.jar:5.3.1]
at org.jboss.netty.handler.stream.ChunkedWriteHandler.handleUpstream(ChunkedWriteHandler.java:142) [ums.jar:5.3.1]
at org.jboss.netty.handler.codec.http.HttpChunkAggregator.messageReceived(HttpChunkAggregator.java:145) [ums.jar:5.3.1]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296) [ums.jar:5.3.1]
at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:459) [ums.jar:5.3.1]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:536) [ums.jar:5.3.1]
at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435) [ums.jar:5.3.1]
at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [ums.jar:5.3.1]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) [ums.jar:5.3.1]
at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) [ums.jar:5.3.1]
at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) [ums.jar:5.3.1]
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108) [ums.jar:5.3.1]
at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337) [ums.jar:5.3.1]
at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89) [ums.jar:5.3.1]
at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) [ums.jar:5.3.1]
at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [ums.jar:5.3.1]
at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) [ums.jar:5.3.1]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [na:1.8.0_65]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [na:1.8.0_65]
at java.lang.Thread.run(Unknown Source) [na:1.8.0_65]
DEBUG 2015-12-02 14:21:52.044 [cling-14] TransportState: TRANSITIONING
DEBUG 2015-12-02 14:21:52.304 [ffmpeg64.exe-2] Starting C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe -y -loglevel info -i H:\Downloads\Ubuntu\Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD[brassetv]\Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD.mkv -bufsize 1835000 -maxrate 44000000 -g 5 -q:v 1 -qmin 2 -qmax 3 -c:a copy -c:v mpeg2video -f vob \\.\pipe\ffmpegvideo_61_1449026511989
DEBUG 2015-12-02 14:21:52.309 [ffmpeg64.exe-2] Reading pipe: \\.\pipe\ffmpegvideo_61_1449026511989
TRACE 2015-12-02 14:21:52.335 [ffmpeg64.exe-2] Successfully initialized buffer to 52,428,800 bytes.
DEBUG 2015-12-02 14:21:52.335 [ffmpeg64.exe-2] Attaching thread: ffmpeg64.exe-2
TRACE 2015-12-02 14:21:52.337 [ffmpeg64.exe-2-Timer] buffered: 0 bytes / inputs: 0
INFO 2015-12-02 14:21:52.337 [ffmpeg64.exe-2-1] Exception in thread "ffmpeg64.exe-2-1" java.lang.NullPointerException
INFO 2015-12-02 14:21:52.338 [ffmpeg64.exe-2-1] at net.pms.io.OutputBufferConsumer.run(OutputBufferConsumer.java:55)
DEBUG 2015-12-02 14:21:52.346 [ffmpeg64.exe-2-2] ffmpeg version N-76250-g7c8fcbb Copyright (c) 2000-2015 the FFmpeg developers
DEBUG 2015-12-02 14:21:52.346 [ffmpeg64.exe-2-2] built with gcc 5.2.0 (GCC)
DEBUG 2015-12-02 14:21:52.347 [ffmpeg64.exe-2-2] configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libdcadec --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-lzma --enable-decklink --enable-zlib
DEBUG 2015-12-02 14:21:52.347 [ffmpeg64.exe-2-2] libavutil 55. 4.100 / 55. 4.100
DEBUG 2015-12-02 14:21:52.347 [ffmpeg64.exe-2-2] libavcodec 57. 9.100 / 57. 9.100
DEBUG 2015-12-02 14:21:52.347 [ffmpeg64.exe-2-2] libavformat 57. 10.102 / 57. 10.102
DEBUG 2015-12-02 14:21:52.347 [ffmpeg64.exe-2-2] libavdevice 57. 0.100 / 57. 0.100
DEBUG 2015-12-02 14:21:52.347 [ffmpeg64.exe-2-2] libavfilter 6. 13.100 / 6. 13.100
DEBUG 2015-12-02 14:21:52.347 [ffmpeg64.exe-2-2] libswscale 4. 0.100 / 4. 0.100
DEBUG 2015-12-02 14:21:52.347 [ffmpeg64.exe-2-2] libswresample 2. 0.100 / 2. 0.100
DEBUG 2015-12-02 14:21:52.347 [ffmpeg64.exe-2-2] libpostproc 54. 0.100 / 54. 0.100
DEBUG 2015-12-02 14:21:52.357 [ffmpeg64.exe-2-2] Input #0, matroska,webm, from 'H:\Downloads\Ubuntu\Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD[brassetv]\Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD.mkv':
DEBUG 2015-12-02 14:21:52.357 [ffmpeg64.exe-2-2] Metadata:
DEBUG 2015-12-02 14:21:52.357 [ffmpeg64.exe-2-2] encoder : libebml v1.2.0 + libmatroska v1.1.0
DEBUG 2015-12-02 14:21:52.357 [ffmpeg64.exe-2-2] creation_time : 2015-10-31 07:44:51
DEBUG 2015-12-02 14:21:52.357 [ffmpeg64.exe-2-2] Duration: 00:42:30.76, start: 0.000000, bitrate: 5523 kb/s
DEBUG 2015-12-02 14:21:52.357 [ffmpeg64.exe-2-2] Stream #0:0: Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
DEBUG 2015-12-02 14:21:52.357 [ffmpeg64.exe-2-2] Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)
DEBUG 2015-12-02 14:21:52.358 [ffmpeg64.exe-2-2] \\.\pipe\ffmpegvideo_61_1449026511989: No such file or directory
TRACE 2015-12-02 14:21:52.361 [ffmpeg64.exe-2] EOF
INFO 2015-12-02 14:21:52.362 [ffmpeg64.exe-2] Process C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe has a return code of 1! Maybe an error occurred... check the log file
TRACE 2015-12-02 14:21:52.504 [New I/O worker #4] Sleeping for 2500 milliseconds
TRACE 2015-12-02 14:21:53.817 [UPNPHelper] Receiving a M-SEARCH from [192.168.0.19:1901]
TRACE 2015-12-02 14:21:54.336 [ffmpeg64.exe-2-Timer] buffered: 0 bytes / inputs: 0
TRACE 2015-12-02 14:21:55.004 [New I/O worker #4] Finished sleeping for 2500 milliseconds
TRACE 2015-12-02 14:21:55.004 [New I/O worker #4] Did not send subtitle headers because mediaRenderer.getSubtitleHttpHeader returned either null or blank
TRACE 2015-12-02 14:21:55.006 [New I/O worker #4] Matched support line f:mpegps|mpegts m:video/mpeg v:mpeg2|h264 a:ac3|aac|mpa
DEBUG 2015-12-02 14:21:55.006 [StartPlaying Event] Matched media renderer "BRAVIA KDL-40W5500 " based on address /192.168.0.14
INFO 2015-12-02 14:21:55.007 [StartPlaying Event] Started playing Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD.mkv on your BRAVIA KDL-40W5500
TRACE 2015-12-02 14:21:55.007 [New I/O worker #4] Ready to Stop: true
DEBUG 2015-12-02 14:21:55.008 [StartPlaying Event] The full filename of which is: H:\Downloads\Ubuntu\Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD[brassetv]\Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD.mkv and the address of the renderer is: 192.168.0.14
TRACE 2015-12-02 14:21:55.009 [New I/O worker #4] Sent to socket: TransferMode.DLNA.ORG: Streaming
TRACE 2015-12-02 14:21:55.009 [New I/O worker #4] Sent to socket: Content-Type: video/mpeg
TRACE 2015-12-02 14:21:55.009 [New I/O worker #4] Sent to socket: ContentFeatures.DLNA.ORG: DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01700000000000000000000000000000
TRACE 2015-12-02 14:21:55.009 [New I/O worker #4] Sent to socket: Accept-Ranges: bytes
TRACE 2015-12-02 14:21:55.009 [New I/O worker #4] Sent to socket: Connection: keep-alive
TRACE 2015-12-02 14:21:55.009 [New I/O worker #4] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/5.3.1
TRACE 2015-12-02 14:21:55.018 [New I/O worker #5] Opened request handler on socket /192.168.0.14:61955
TRACE 2015-12-02 14:21:55.019 [New I/O worker #5] Request: HTTP/1.1 : GET : get/129/Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD.mkv_transcoded_to.mpg
DEBUG 2015-12-02 14:21:55.019 [New I/O worker #5] Matched media renderer "BRAVIA KDL-40W5500 " based on address /192.168.0.14
TRACE 2015-12-02 14:21:55.019 [New I/O worker #5] Received on socket: TimeSeekRange.dlna.org: npt=0.000-
TRACE 2015-12-02 14:21:55.019 [New I/O worker #5] Received on socket: getcontentFeatures.dlna.org: 1
TRACE 2015-12-02 14:21:55.019 [New I/O worker #5] Received on socket: Pragma: getIfoFileURI.dlna.org
TRACE 2015-12-02 14:21:55.019 [New I/O worker #5] Received on socket: transferMode.dlna.org: Streaming
TRACE 2015-12-02 14:21:55.019 [New I/O worker #5] Received on socket: Host: 192.168.0.25:5001
TRACE 2015-12-02 14:21:55.019 [New I/O worker #5] Recognized media renderer: BRAVIA KDL-40W5500
TRACE 2015-12-02 14:21:55.019 [New I/O worker #5] HTTP: get/129/Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD.mkv_transcoded_to.mpg / 0-0
TRACE 2015-12-02 14:21:55.020 [New I/O worker #5] Asked stream chunk : TimeRange [start=0.0, end=null] of Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD.mkv and player FFmpeg
TRACE 2015-12-02 14:21:55.020 [New I/O worker #5] Ready to Stop: false
TRACE 2015-12-02 14:21:55.020 [New I/O worker #5] Did not send subtitle headers because mediaRenderer.getSubtitleHttpHeader returned either null or blank
TRACE 2015-12-02 14:21:55.021 [New I/O worker #5] Matched support line f:mpegps|mpegts m:video/mpeg v:mpeg2|h264 a:ac3|aac|mpa
TRACE 2015-12-02 14:21:55.022 [New I/O worker #5] Ready to Stop: true
TRACE 2015-12-02 14:21:55.023 [New I/O worker #5] Sent to socket: TransferMode.DLNA.ORG: Streaming
TRACE 2015-12-02 14:21:55.023 [New I/O worker #5] Sent to socket: Content-Type: video/mpeg
TRACE 2015-12-02 14:21:55.023 [New I/O worker #5] Sent to socket: ContentFeatures.DLNA.ORG: DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=11;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01700000000000000000000000000000
TRACE 2015-12-02 14:21:55.023 [New I/O worker #5] Sent to socket: Accept-Ranges: bytes
TRACE 2015-12-02 14:21:55.023 [New I/O worker #5] Sent to socket: Connection: keep-alive
TRACE 2015-12-02 14:21:55.023 [New I/O worker #5] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/5.3.1
TRACE 2015-12-02 14:21:55.023 [New I/O worker #5] Sent to socket: TimeSeekRange.dlna.org: npt=00:00:00.00-00:42:30.00/00:42:30.00
TRACE 2015-12-02 14:21:55.023 [New I/O worker #5] Sent to socket: X-Seek-Range: npt=00:00:00.00-00:42:30.00/00:42:30.00
DEBUG 2015-12-02 14:21:55.558 [cling-10] TransportStatus: ERROR_OCCURRED
DEBUG 2015-12-02 14:21:55.558 [cling-10] TransportState: STOPPED
TRACE 2015-12-02 14:21:56.336 [ffmpeg64.exe-2-Timer] buffered: 0 bytes / inputs: 0
DEBUG 2015-12-02 14:21:57.511 [ffmpeg64.exe-2-Cleanup] Stopping process: ffmpeg64.exe-2
TRACE 2015-12-02 14:21:57.511 [ffmpeg64.exe-2-Cleanup] Destroying buffer
TRACE 2015-12-02 14:21:58.481 [UPNPHelper] Receiving a NOTIFY from [192.168.0.21:61473]
DEBUG 2015-12-02 14:21:59.040 [StopPlaying Event] Matched media renderer "BRAVIA KDL-40W5500 " based on address /192.168.0.14
INFO 2015-12-02 14:21:59.040 [StopPlaying Event] Stopped playing Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD.mkv on your BRAVIA KDL-40W5500
DEBUG 2015-12-02 14:21:59.041 [StopPlaying Event] The full filename of which is: H:\Downloads\Ubuntu\Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD[brassetv]\Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD.mkv and the address of the renderer is: 192.168.0.14
DEBUG 2015-12-02 14:21:59.042 [StopPlaying Event] adding "Pacific.Warriors.S01E02.Big.Island.Breakdown.720p.HDTV.x264-DHD" to playlist "Recently Played"
TRACE 2015-12-02 14:22:03.814 [UPNPHelper] Receiving a M-SEARCH from [192.168.0.19:1901]
DEBUG 2015-12-02 14:22:07.829 [AWT-EventQueue-0] Checking dbgpack property in UMS.conf
DEBUG 2015-12-02 14:22:07.829 [AWT-EventQueue-0] adding C:\Program Files (x86)\Universal Media Server\renderers\Sony-Bravia5500.conf
DEBUG 2015-12-02 14:22:07.829 [AWT-EventQueue-0] adding C:\ProgramData\UMS\WEB.conf
DEBUG 2015-12-02 14:22:07.830 [AWT-EventQueue-0] adding C:\ProgramData\UMS\UMS.conf
DEBUG 2015-12-02 14:22:07.830 [AWT-EventQueue-0] adding C:\ProgramData\UMS\debug.log.prev
DEBUG 2015-12-02 14:22:24.942 [AWT-EventQueue-0] Packing C:\Program Files (x86)\Universal Media Server\renderers\Sony-Bravia5500.conf
DEBUG 2015-12-02 14:22:24.944 [AWT-EventQueue-0] Packing C:\ProgramData\UMS\WEB.conf
DEBUG 2015-12-02 14:22:24.945 [AWT-EventQueue-0] Packing C:\ProgramData\UMS\UMS.conf
DEBUG 2015-12-02 14:22:24.950 [AWT-EventQueue-0] Packing C:\ProgramData\UMS\debug.log.prev
DEBUG 2015-12-02 14:22:24.957 [AWT-EventQueue-0] Packing C:\ProgramData\UMS\debug.log
<s:Body>
</u:BrowseResponse>
</s:Body>
</s:Envelope>
Re: Sony KDL-40W5500 failing to play videos
can i help by providing any further information?
Yes you can. Please follow the instruction written in red above. Also, did you make a clean install of UMS?ozhammer wrote:can i help by providing any further information?
Yes clean install and clean restartvalib wrote:Yes you can. Please follow the instruction written in red above. Also, did you make a clean install of UMS?ozhammer wrote:can i help by providing any further information?
