Disable silence between songs
When playing music (MP3, FLAC), is there a way to disable the silence/pause between songs? I am using Foobar2000 for a long time, and I really miss this feature when using UMS to play music - especially when playing live music.
Thanks and all best.
Re: Disable silence between songs
Is there not an option to solve this? Thanks and all best.
Hi starterz, it isn't an option that we can do on our end, it would need to be a feature on your renderer
Ah OK, thanks for the reply. At least I am clear on the issue
All best.
All best.
