2.3.0 Problems [Bravia W5500]
squadjot
Post by squadjot »
I fired up 2.3.0 to test the subtitle problems i've had lately [Clean install], and sadly, found out that a great deal of files turned unplayable in 2.3.0
Most files played with 2.2.5!, infact i can't recall any that wouldnt..
Those files failing in debug.log, definately all played fine with 2.2.5.
ums_dbg_28jan2013.zip
(20.21 KiB) Downloaded 494 times
ExSport
Re: 2.3.0 Problems [Bravia W5500]
Post by ExSport »
None of the files in log played?
After 10 secs MEncoder process was stopped. Can't say if due to any problem or what.
Try changing log level to TRACE, restart and reproduce problem again.
Also it will be good to do the same with working 2.2.5 so we can compare both logs.
squadjot
Post by squadjot »
OK, the last file in debug.log played "blades of glory", the rest gave a "Playback unavailable" -message
squadjot
Post by squadjot »
:shock: Ok, weird now those files dont' play with 2.2.5 either (reinstalled it/clean install in separate folder)..
Edit: Ok, after fidddling abit , i changed sound encoding to 2channel/384 , that made the movies play again. ( also in 2.3.0 , i guess they share default config file )
- Changing back to 5.1channel/640 did not reproduce the "bug"
Will try to clean install 2.3.0 again, and see if it happens same way again.
Edit2: Hmm, it's harder to locate the problem than i thought.. i reinstalled UMS 2.3.0 , but now i can't make it play the files again :P
I think it requires some more restarting computer between each setting, because i suspect something to crash, also javaw hangs.. like something is wrong (also server is *avail on TV even if PMS UI is shutdown, *atleast i can browse "backwards")
Edit3: I'm pretty sure UMS works fine.. there's just something in the "out-the-box"-settings that does that some files wont play (and makes java lock/hang)
