UMS folder scan issues
I have 2 issues with the processing of the UMS folders
1. when you first load UMS it defaults to 'all drives'. If you then start adding new directories and process a rescan it still tries to include 'all drives'. Having added the required media directories (which replace the default 'all drives') you then need to restart UMS in order for the scanning of 'all drives' to be skipped.
2. I have a lot of media which when scanning causes a 'heap memory' error - java.lang.OutOfMemoryError: Java heap space. I reinstalled with a larger memory space but still encountered the same issue. I also tried a fresh install.
See the attached log file ...
- debug.log.rar
- (411.25 KiB) Downloaded 570 times
