Mythtvlive plugin
Mythtvlive plugin
I have just started using UMS and it is just what I needed. However I am trying to get the mythlive plugin working with mythtv 0.28. I am having issues getting it to compile. Has anyone managed to upgrade the plugin or write a newer one? Thanks in advance for you help.
I have been looking at the code for the plugin and it should be easy enough to get it working with 0.28 I just cant get it to compile, is there any guides on how to build the plugins?
Regards
Andrew
Regards
Andrew
Re: Mythtvlive plugin
You should kindly ask Nadar of help
Linking the source code found in UMS plugins link:
https://code.google.com/archive/p/mythtvlive/
