UMS seems to get stuck on last folder when building cache
chamelious
Doesn't seem to mention in the logs, it just remains on "scanning LASTFOLDER" indefinitely, and when UMS is closed and reopened "enable the cache" is no longer selected. Latest version of UMS on W7_64, has defo worked in the past!
Any ideas?
Any ideas?
Re: UMS seems to get stuck on last folder when building cache
Follow the red text above.
chamelious
Attached.
- (1.34 MiB) Downloaded 497 times
I've looked at it and been unable to replicate your results. The debug files doesn't give me enough information to be sure what is going wrong, although I can see that something is going wrong at the end.
I've built a modified version of UMS with extra logging around the place where it crashed to try to pin exactly what is going wrong. You can download it here. Please install this version, create new debug files while scanning and post them here.
chamelious
Thanks, installed and rerun.
- (1.33 MiB) Downloaded 468 times
Your cache is corrupt and disables itself during scan. Not a very good solution, but there is a log entry for it which I missed:
I don't know which recovery tool the error mentions, the easy solution is to just delete the cache file. The cache file is:
UMS profile folder is by default and in your case located here:
I'll see if I can find any way to make this a bit more clear if it happens, I didn't even spot it myself
DEBUG 2016-01-28 08:11:45.740 [AWT-EventQueue-0] net.pms.dlna.DLNAMediaDatabase Cache connection error: File corrupted while reading record: null. Possible solution: use the recovery tool [90030-191]
<UMS profile folder>/database/medias.mv.dbCode: Select all
C:\ProgramData\UMS\
chamelious
Many thanks that seems to have worked.
