Problem Uploading attachments with IE9?
Post in here if you spot any issues or suggestions for this website
squadjot
Re: How to ask for support
Post by squadjot »
Just FYI, i have problems uploading files to posts when using my IE(9.0.8112.16421)
Re: Problem Uploading attachments with IE9?
Ah I see the problem, you're using IE :D Hehe I'll look into it
squadjot
Post by squadjot »
Again..was only trying to help, some users actually use IE =)
I got a "board warning" cause i was posting it in How to ask for support..i thoguht it was related.. i'm very sorry
Was the warning from optimus_prime? Well I suppose it's a fair reason for a warning although I wouldn't have given it since you're a regular.
I'll try it in IE9 tomorrow and if I can reproduce the issue I can probably fix it
kuroukage
Post by kuroukage »
Use Firefox. :P
squadjot
Post by squadjot »
Yeah, i get offended easily xD j/k
Ok, thanks. Mostly cencerned with newbies giving up on submitting precious debug.logs =)
Yep firefox works
kuroukage
Post by kuroukage »
Just gotta make sure the newbies are using Firefox. Spread the word and help them out! ;)
Optimus_prime
Post by Optimus_prime »
My apoligies, squadjot for the warning.
I thought i'd removed it after i did it. Was only ment to send a pm :(
The warning expires in 90 days. I'll PM Subjunk to see if he will shorten the duration for the forum.
No problem, Optimus, I removed the warning :) On other forums I've found warnings to be discouraging so I would probably stay away from them and PM instead, seems friendlier :) I know Firefox isn't an option for some people so I will still test IE9
Testing
