how can i disable foced subs?
firstcolle
hi,
how can i disable the forced subtitles in some MKVs without usa the disable subtitles checkbox?
i mean: i wont to always start my media without any kind of subtitles even if the subtitle is tagged as forced in the media files. when i need subs i prefer to select it manually from the transcoded folder
thanks
thanks
firstcolle
Re: how can i disable foced subs?
solved by typing "null" in the forced tags box
UMS is always the best once you know how to set it up!!!
It will work with whatever you type there as long as it doesn't match part of the subtitle file name.
firstcolle
god to know!!!Nadahar wrote:It will work with whatever you type there as long as it doesn't match part of the subtitle file name.
many thanks!
Better to say part of the subtitle flavor what can be tag for embedded subs or part of the subtitle name like moviename.en-forced.srt.
Flavor/tag is detected as part after subtitle language tag divided by "-".
Using irrelevant forced tag or forced language is the way to go
