Add Media Library in UMS
I was trying to make UMS work with WMP12 and my Samsung tablet without installing other apps. After searching the forum and found no solution, I decided to investigate this issue by myself.
I did some research on software which works fine with WMP (i.e. I can browse my music directly inside WMP), in this case, it's foobar2000 with foo_upnp component. And I found that my music shows up after I enabled "Show Media Library" under UPNP settings in foobar2000. So I guess UMS also needs this "Media Library" thing to work with WMP and my tablet.
Note: foo_upnp is powered by an open source SDK called Platinum UPnP and its source code can be found here: http://sourceforge.net/projects/platinum/files/
Hope that helps:)
Hope that helps:)
