[solved] Errors Java or SQL
I have these errors in ums. What is the issue ?
debug.log- (552.05 KiB) Downloaded 498 times
Re: Errors Java or SQL
This should be a hint:
There's probably permission problems with the database file. It's called "medias" with some extension(s). Make sure the UMS user can write to this file.
org.h2.jdbc.JdbcSQLException: The database is read onlyRe: Errors Java or SQL
That's it. It is fine now. Thank you.
