UMS 6.1.0 java 8 doesn't work on os x 10.11.3
Dear developers, I'm trying to running UMS but with no success.
As mentioned in the subject, I downloaded the lastest ums version (6.1.0) for java 8.
Here my system info:
Here the error I get:
I've tried before with java 1.7.0_40 (my java jdk wasn't updated) but I got the same error.
Any suggestions? Thank you for helping.
Regards,
Riccardo
sw_vers
ProductName: Mac OS X
ProductVersion: 10.11.3
BuildVersion: 15D21Code: Select all
java -version
java version "1.8.0_73"
Java(TM) SE Runtime Environment (build 1.8.0_73-b02)
Java HotSpot(TM) 64-Bit Server VM (build 25.73-b02, mixed mode)Code: Select all
./JavaAppLauncher
Exception in thread "main" java.lang.NoSuchMethodError: org.slf4j.spi.LocationAwareLogger.log(Lorg/slf4j/Marker;Ljava/lang/String;ILjava/lang/String;[Ljava/lang/Object;Ljava/lang/Throwable;)V
at org.apache.commons.logging.impl.SLF4JLocationAwareLog.debug(SLF4JLocationAwareLog.java:131)
at org.apache.commons.configuration.AbstractFileConfiguration.setBasePath(AbstractFileConfiguration.java:626)
at org.apache.commons.configuration.PropertiesConfiguration.setBasePath(PropertiesConfiguration.java:549)
at org.apache.commons.configuration.AbstractFileConfiguration.load(AbstractFileConfiguration.java:314)
at org.apache.commons.configuration.AbstractFileConfiguration.load(AbstractFileConfiguration.java:286)
at net.pms.configuration.PmsConfiguration.<init>(PmsConfiguration.java:545)
at net.pms.configuration.PmsConfiguration.<init>(PmsConfiguration.java:527)
at net.pms.PMS.main(PMS.java:1166)Any suggestions? Thank you for helping.
Regards,
Riccardo
Re: UMS 6.1.0 java 8 doesn't work on os x 10.11.3
im having the same issue tried uninstalling and reinstalling still doesn't work
For me 6.10 does work (JAVA 8.x, OS X 10.11.3 El Capitan)!
Log:
10:50:45 INFO Starting Universal Media Server 6.1.0
10:50:45 INFO Based on PS3 Media Server by shagrath, copyright 2008-2014
10:50:45 INFO http://www.universalmediaserver.com
10:50:45 INFO
10:50:45 INFO Build: 7fbc2dd47 (2016-02-20)
10:50:45 INFO Java: Java HotSpot(TM) 64-Bit Server VM 1.8.0_73 64-bit by Oracle Corporation
10:50:45 INFO OS: Mac OS X 64-bit 10.11.3
No probs here. (Hackintosh PC)
Log:
10:50:45 INFO
Please can you run "java -version" on a terminal and show me the output?mitchde wrote:For me 6.10 does work (JAVA 8.x, OS X 10.11.3 El Capitan)!
Log:
10:50:45 INFO
GA-EP35:~ andreasm$ java -version
java version "1.7.0_07"
Java(TM) SE Runtime Environment (build 1.7.0_07-b10)
Java HotSpot(TM) 64-Bit Server VM (build 23.3-b01, mixed mode)
GA-EP35:~ andreasm$
6.1 running OK.
GA-EP35:~ andreasm$
6.1 running OK.
Uhmm this is weird, in your ums log it's clear it uses java 8, but the java running on your terminal is java 7 (and a very old release). So probably I need to understand from ums log which version ums is using. Unfortunately before the message error I don't have any useful information (like the java version called).
In any case thank you for your help mitchde.
Any addtional help from other users is welcome.
Bye
Riccardo
Bye
Riccardo
I posted the above in viewtopic.php?f=11&t=6074 I have since installed UMS 6.1.0 and still NO success with the same error message is "The application “Universal Media Server.app” can’t be opened"FineWine wrote:I too have just installed the latest version of UMS and are having problems to do with Java on Mac OS10.11.3
Completely uninstalled UMS
I then completely uninstalled ALL VERSIONS of Java.
I then installed the latest Java Version 8 Update 73
Installed UMS version 6 but it complained it needed Java 6SE
I uninstalled UMS again
I then installed OS X 2015-001 which installs the legacy Java 6 runtime for OS X 10.11 El Capitan
Now the error message is "The application “Universal Media Server.app” can’t be opened"
I then uninstalled UMS version 6 and installed UMS 5.2.2 and all works fine.
So there is a problem with UMS version 6
I have changed my Security settings to "Allow Apps downloaded from: Anywhere" and still NO luck.
This problem wouldn't by any change have anything to do with El Capitan's new "System Integrity Protection (SIP) a new security feature introduced by Apple?"
This is all very annoying because I love UMS it used to work well with my Kiwi Panasonic Equipment.
Please find a fix for the latest UMS versions as I have had to revert back to 5.2.2
I'm having this exact issue. Also on 10.11.3 and when I open UMS it asks me to pick a language, then after I do, nothing happens.
UMS shows in tray but no windows, nothing. Java 8 installed.
Re: UMS 6.2.1 java 8 doesn't work on os x 10.11.4
UMS 6.2.1 java 8 doesn't work on os x 10.11.4 either. (using latest java 8 update 77 build 03)
Interesting that no one, moderators, UMS techie people have not really replied in these forums concerning this issue.
Same problem.
