PMSEncoder match error when playing Youtube video
This started after upgrading Java to 7u13. I have uninstalled and reloaded 7u9 but still having the same error.
- (401.51 KiB) Downloaded 553 times
Re: PMSEncoder match error when playing Youtube video
From looking at your UMS.conf file you don't seem to have anything setup at all. Do you have Youtube-DL? Or RTMPDump? If not DL those files, make a dir on your C: drive (call it bin) and throw those two files in there. You then need to make sure to add these lines to the end of your UMS.conf:
Do all this while UMS isn't running. Then load when done and try your Youtube links again.
Also, I'd recommend doing a clean re-install of Java v7u13. The version you're using is unsafe and full of security problems.
rtmpdump.path = C:\\bin\\rtmpdump.exe
youtube-dl.path = C:\\bin\\youtube-dl.exeAlso, I'd recommend doing a clean re-install of Java v7u13. The version you're using is unsafe and full of security problems.
Still not fixed. Problem is only on the YouTube videos.
Post a new set of logs, please.
