PMS 1.54 Can Play New Release Which UMS 2.42 Can't
rockphantom
Post by rockphantom »
Howdy,
I downloaded a 720p HDTV broadcast from last night in MKV format. When I attempted to play the file on my PS3 via UMS 2.42, UMS would hang at a black screen before the first frame of the video appeared. As a last resort, I used the ancient Playstation Media Server 1.54 to play the video, and much to my surprise my PS3 was able to transcode the 720p capture without any issues.
Could someone please explain why UMS has issues playing a video that an ancient version of PMS has no problems with?
Thank You!
Milan
Optimus_prime
Re: PMS 1.54 Can Play New Release Which UMS 2.42 Can't
Post by Optimus_prime »
hi milan,
Thanks for using UMS and posting the issue your having.
Could you please follow this info in the post here viewtopic.php?f=9&t=556
this will assist the guys here in trying to fix your issue
rockphantom
Attached to this post is the log file for the MKV file that hangs before the first frame of the video.
Please let me know if further information is needed.
Thank You!
Milan
(18.56 KiB) Downloaded 483 times
Thanks for the log. Can you also post the log for PMS?
rockphantom
Enclosed in this post is the PMS 1.54 log that Subjunk requested.
Thanks,
Milan
02.18.13 PMS 1.54 debug.log.zip
(7.13 KiB) Downloaded 543 times
OK it's like I thought, PMS is using MEncoder while UMS is using tsMuxeR. You can go into the transcode folder in UMS and select MEncoder (or even better FFmpeg)
rockphantom
I've switched the Video File Engine of UMS 2.42 from TsMuxer to MEncoder, and restarted the server.
The video is still stuck at the same spot. I've also enabled FFMPEG as the default encoder and received the same error.
Enclosed is the log of the MEncoder UMS attempt.
Thank You for your help!
Milan
ums_dbg 02.18.13 II.zip
(53.29 KiB) Downloaded 527 times
Looks like you've found a bug in our build of MPlayer, thanks for the report. I will try to fix it for the next version :)
rockphantom
I'm glad to help, Sub Junk.
I've downloaded an alternate 720p capture of the HDTV broadcast in question and it streams to my PS3 via UMS 2.42 flawlessly using FFmpeg and MEncoder.
Thank you for all that you do!
Milan
