TSMuxer doesnt show all audio tracks
Marcelo90
Post by Marcelo90 »
Sorry for my bad english, im from Spain.
Well, my PS3 works all fine with UMS but, tsMuxer cant show all audio tracks from a file. With PMS i´ve never got this problem, and never changed his config.
In UMS, i´ve checked the Mux all audio tracks and still the problem... only shows 1 audio.
Thank you all!!
Re: TSMuxer doesnt show all audio tracks
I just tested and it works for me with 2 AC-3 audio tracks, can you give me more info on the file you're having problems with?
Marcelo90
Post by Marcelo90 »
It is in all of the files I have. Only shows the audio that is "checked" by default.
Example: if the movie has spanish, english and japanese, if the spanish audio is the default, cant choose the other 2 in my PS3.
ExSport
Post by ExSport »
Are you sure you are using (or UMS) tsMuxeR?
  • When MEncoder is used (transcoding), only one audio is available, depending on preference settings or manual choose from TRANSCODE folder
  • When tsMuxeR is used (remuxing) with default settings, only one audio (first track) is muxed. When "Mux all audios" is ticked (in UMS GUI), all audio tracks are available via AUDIO button on remote
  • When file is streamed directly, all audio tracks should be visible, same as with tsMuxeR and "Mux all audios" is enabled
Marcelo90
Post by Marcelo90 »
ExSport wrote:Are you sure you are using (or UMS) tsMuxeR?
Thank you ExSport. I have checked "Mux all audio tracks" and only saw one audio track, but i didnt try to press Audio Options in the menu pressing TRIANGLE on my DualShock3. Now, i can change audio!!! :D
