Minor bug: Subtitle border outline [mencoder]
Hi ..i'm usually using simplest form of subtitles (plain..no ass).. but i DO set the fontsize down a bit, and add extra border to the subtitle.
First of all.. i think the subtitle styling options input fields are a bit of a mess (naming/info wise).
Second, "border" seems to not work anymore. (i'm usually using the 2nd lower one of the two "border" input fields, heck tried em both but wont do anything in 2.5.1)
Edit: This is for when using SRT's ..i dont know/expect it to work with embedded subs (which i never use anyways)
Re: Minor bug: Subtitle border [mencoder]
Install UMS which works, make a test, save debug.log.
Install latest UMS, make same test, save debug.log.
Upload it here or compare both by own.
What interests us is MEncoder parameters part. Are there any differences?
Btw. what do you mean with "borders"? You can set only scale=size, outline=border?, blur and margin=border?
ok ill try,ExSport wrote:Install UMS which works, make a test, save debug.log.
Upload it there or compare both by own.![]()
Yeah, sorry meant the outline border
Edit: And yeah i know how to upload debuglog.. i just thought maybe this was a no brainer when looking in code. (not that i have seen it ^^)
