No renderes found
No renderes found
Hi. I've just started using UMS today and after first installation it worked like a charm on both my Panasonic TV and Onkyo receiver. After I restarted my computed it have never worked again. I tried every other media server available and nothing nada zero.... Always same thing No renderers found.
I would appreciate any help.
I'm on Mountain Lion 10.8.3
debug.log- (9.96 KiB) Downloaded 650 times
Re: No renderes found
Maybe a firewall issue? UPnP uses UDP port 1900 and TCP port 2869
Hi!!
It seems to be getting the IP address from a bridged interface:
First, you should check in Network Preferences on your Mac your Services Order:
You must drag the preferred device (your network LAN connection) on top.
Also, in UMS you can force your networking interface with the one connected to your LAN:
If you are forced to connect through a bridge, check that all the computers and devices on your network are in the same local network address: 192.168.2.*
INFO 2013-03-23 19:08:54.843 [main] Using address /192.168.2.1 found on network interface: name:bridge0 (bridge0)
