Disable serving Images to XBox One
Hello UMS folks,
Is there a way to disable serving ANY kind of image to the XBox One? I tried removing the list of supported image formats in the renderer configuration, but it did not work:
The reason why I need this is that the XBox One media player is such a pile of crap it is unbelievable, don't get me started on this. Besides many others, the biggest showstopper right now is that you cannot play an album (i.e., a folder with .mp3 tracks) if there is a cover image (e.g., 00-cover.jpg) in the same folder. Because if you press "Play All" it will "play" the cover image first and there is no way to advance to the next track, I tried every button on the controller. This is so ridiculous and I basically have to stop sending any images to the console.
Thanks for any help!
# Supported image formats:
#Supported = f:bmp m:image/bmp
#Supported = f:gif m:image/gif
#Supported = f:jpg m:image/jpeg
#Supported = f:png m:image/png
#Supported = f:tiff m:image/tiffThanks for any help!
Re: Disable serving Images to XBox One
Simply add to the Microsoft-XboxOne.conf but I am not sure if it will solve your problem.
Image = falseRe: Disable serving Images to XBox One
Well, it doesn't fix the XBone Media Player, but now I can at least play albums with a cover in it. Thanks!
