Vizio M492i-B2
Vizio M492i-B2
The server is showing up correctly, but I cannot get to any files.
For instance, I have two folders: TV Shows and Movies. Inside is a folder for each program or film. For example:
TV Shows
Is there a way to fix this issue via the configuration files? I tried disabling fast encoding, but that did nothing.
TV Shows
Whenever I navigate to the Night Court folder, UMS is trying to send Episode 1 to my TV and repeatedly gets denied. Meanwhile, my TV is still waiting for the file list in order to make a choice. The TV hangs while UMS tried to force feed it a video file.Night CourtEpisode 1
Episode 2
