UMS probleme pls help
hi everyone,
i'm really pissed about some issues i had recently with UMS/PMS / JAVA 8 /PS3 /Mencoder/...
everything was working fine with PS3 Media server until i had to reinstall WIN 10 64
now i can only play 1 MKV ( if i am lucky) and then i get " Les données sont endomagée " ( sorry i'am french i don't know what the english message here )
every other type of file seems to work fine
it seem that i can play some mkv if they don't have external subtitles (i don't know about internel's ones ) but sometime it's not working either
when USM is connected with the ps3 my PC is like way slower then otherwise like 5-10sec to open any video when it's like less than a sec otherwise
after it crashed i have lots of Mencoder process runing
and above all i can't even start usm if i restart my pc since i installed it i have to install it again
java8 101
last release of usm java8
https://docs.google.com/document/d/14u0 ... 08OdHU/pub
java8 101
Re: UMS probleme pls help
First of all I recommend to uninstall the 32bit Java. You are running the 64bit version of WIN 10 so install the latest 64bit Java version. If it not help try to make a clean re-installation of the UMS.
erick diangilis
yes try the 64 bit version of the same java 101 and don't forget to reset the computer after the install and you can also try the update 112b03 from the oracle website that's the one im using now.
i hope it helps have a good day.
nope still not working
now it give me the
There is no inputstream to return for ...XXX...
and still having that slow PC when connected
and that http://imgur.com/a/cDVjx
it was working fine before ....
PS : it's working wis low res files like mp4 and avi
now it give me the
