Can not play mp3
Can not play mp3
I'm running the latest 6.5.0 on Fedora 24 to PS4.
Video files can be played perfectly but mp3 can not be.
I checked every release since 5.2.3 but never played.
I check with PS3 media server 1.90.1 and surprisingly plays both video (mp4) and audio (mp3). (Video wasn't played before. PS4 might be tuned up.)
Is there anything to do to play mp3 on ums?
Re: Can not play mp3
Can you post the output of following cmd?
ffmpeg -i fileRe: Can not play mp3
Here it is.
Thanks.
Thanks.
ffmpeg -i file
ffmpeg version 3.0.3 Copyright (c) 2000-2016 the FFmpeg developers
built with gcc 6.1.1 (GCC) 20160621 (Red Hat 6.1.1-3)
configuration: --prefix=/usr --bindir=/usr/bin --datadir=/usr/share/ffmpeg --incdir=/usr/include/ffmpeg --libdir=/usr/lib64 --mandir=/usr/share/man --arch=x86_64 --optflags='-O2 -g -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -m64 -mtune=generic' --enable-bzlib --disable-crystalhd --enable-fontconfig --enable-frei0r --enable-gcrypt --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libcdio --enable-libfaac --enable-nonfree --enable-indev=jack --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libmp3lame --enable-openal --enable-opencl --enable-libopencv --enable-opengl --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libv4l2 --enable-libvpx --enable-libx264 --enable-libx265 --enable-x11grab --enable-avfilter --enable-avresample --enable-postproc --enable-pthreads --disable-static --enable-shared --enable-gpl --disable-debug --disable-stripping --shlibdir=/usr/lib64 --enable-runtime-cpudetect
WARNING: library configuration mismatch
avdevice configuration: --prefix=/usr --bindir=/usr/bin --datadir=/usr/share/ffmpeg --incdir=/usr/include/ffmpeg --libdir=/usr/lib64 --mandir=/usr/share/man --arch=x86_64 --optflags='-O2 -g -pipe -Wall -Werror=format-security -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -specs=/usr/lib/rpm/redhat/redhat-hardened-cc1 -m64 -mtune=generic' --enable-bzlib --disable-crystalhd --enable-fontconfig --enable-frei0r --enable-gcrypt --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libcdio --enable-indev=jack --enable-libfreetype --enable-libfribidi --enable-libgsm --enable-libmp3lame --enable-openal --enable-opencl --enable-libopencv --enable-opengl --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libv4l2 --enable-libvpx --enable-libx264 --enable-libx265 --enable-x11grab --enable-avfilter --enable-avresample --enable-postproc --enable-pthreads --disable-static --enable-shared --enable-gpl --disable-debug --disable-stripping --shlibdir=/usr/lib64 --enable-runtime-cpudetect
libavutil 55. 17.103 / 55. 17.103
libavcodec 57. 24.102 / 57. 24.102
libavformat 57. 25.100 / 57. 25.100
libavdevice 57. 0.101 / 57. 0.101
libavfilter 6. 31.100 / 6. 31.100
libavresample 3. 0. 0 / 3. 0. 0
libswscale 4. 0.100 / 4. 0.100
libswresample 2. 0.101 / 2. 0.101
libpostproc 54. 0.100 / 54. 0.100
file: No such file or directory
The file refers to the media file with full path
. Go to the directory where the file resides and run the command - possibly that would be easier for you.
Here it is.
ffmpeg -i 01\ -\ Sambandrea\ Swing.mp3
[mp3 @ 0x1a8d8c0] Skipping 0 bytes of junk at 1965.
[mp3 @ 0x1a8d8c0] Estimating duration from bitrate, this may be inaccurate
Input #0, mp3, from '01 - Sambandrea Swing.mp3':
Metadata:
title : Sambandrea Swing
publisher : Concord Jazz
genre : Jazz
album : Dynamite!
track : 01
album_artist : Louis Bellson
composer : Don Menza
artist : Louie Bellson Big Band
TLEN : 423000
date : 2002
Duration: 00:07:02.67, start: 0.000000, bitrate: 128 kb/s
Stream #0:0: Audio: mp3, 44100 Hz, stereo, s16p, 128 kb/s
At least one output file must be specified
I notice that it can be played on iPad or iPhone.
Not played only on PS4 so I assume it's PS4 issue.
