A_EAC3 how to play with ums?
HT1
Post by HT1 »
got this mkv and the audio is A_EAC3
i have k-lite mega codecs installed
how do i play it on tv and hear audio?
Win 10 64bits
Qnap TS-212 2x3TB WD Red
Sony Bravia MN (my own conf)
HT1
Re: A_EAC3 how to play with ums?
Post by HT1 »
still no idea how to play A_EAC3 files. it's becoming more and more common.
can ums handle A_EAC3 ?
what is the solution for use with ums if tv can;t play it ?
Win 10 64bits
UMS should normally transcode the file into something your TV can play. However, the text in red above states some simple steps to take if you want anybody to look at your case.
HT1
Post by HT1 »
thanks for reminding me, here are the logs
(50.86 KiB) Downloaded 509 times
Win 10 64bits
valib
Post by valib »
You set
Skip transcoding
for
mkv,mp4
so those formats are forced to be streamed regardles the TV.conf setting. So if you try to play MKV video with audio format not supported by your TV it doesn't work. Leave that option empty since it is recommended to use only for troubleshooting.
HT1
Post by HT1 »
that sounds logical, i tried it, but the tv just doesn't want to work with ums.
here's the audio part of the mediainfo for the file in question:
Audio
Format : E-AC-3
Format/Info : Enhanced Audio Coding 3
Codec ID : A_EAC3
Duration : 42 min 49 s
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Frame rate : 187.500 FPS (256 SPF)
Compression mode : Lossy
Stream size : 196 MiB (8%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
so the file works on pc. but for some reason it doesn't on tv
Win 10 64bits
@HT1 You need to generate new debug files after having turned off skip transcoding, so we can see what happens then.
