How to disable subtitles on MKV files by default
I have used the line:
However, I still continue to receive subtitles on every .mkv file that UMS encounters. I can disable it using the media player UI, but I don't see a setting for disabling it default. Any suggestions?
If the "disable_subtitles" setting should do the trick, then I guess I'll head over to the Linux specific forums to figure out why it's not reading the config file that the startup says that it's reading...
Thanks.
disable_subtitles = true
Thanks.
