UHD Renderer - Sharp
For a week I try my Sharp UHD with 4k videos to run, unfortunately without success.
Normal videos run, but 4k I always get the following error:
13:23:26 INFO Process "C:\Program Files (x86)\DLNA-Server\win32\ffmpeg.exe" has a return code of 1! Maybe an error occurred... check the log file
I've read a lot and searched, but found nothing which helped me. Has anyone an idea, or solved the problem already?
Re: UHD Renderer - Sharp
I'm one step further when I disable the subtitles running the videos. Unfortunately, only in 1080p and not in 4k. What can I do?
I have already created a profile with the following settings:
MaxVideoWidth = 4096
MaxVideoHeight = 2160
SupportedVideoBitDepths = 12
TranscodeVideo = MPEGTS-H265-AAC
TranscodeVideo = MPEGTS-H264-AAC
TranscodeVideo = MPEGTS-H265-AC3
