LG TV No DTS
Jaz808
LG TV No DTS
Post by Jaz808 »
I have a LG 55LW6500 3D Cinema TV, and it doesn't support DTS, most modern LG TV's dont,
LG didnt pay the licensing or somethining like that
Is there a way for UMS to transcode DTS on the fly to AC3 or something ?
On another note my TV didnt have the correct Rendeer/Config it was seen as the LG Smart Box addon, LG ST600, and that caused some mkvs not to load, then the TV loses connection to the server
Re: LG TV No DTS
Jaz808 wrote:Is there a way for UMS to transcode DTS on the fly to AC3 or something ?
Yes, that is the default option for the server. DTS serving is disabled by default. In the LG Smart TV Upgrader it is enabled by default but that is one of the rare cases.
Jaz808 wrote:On another note my TV didnt have the correct Rendeer/Config it was seen as the LG Smart Box addon, LG ST600, and that caused some mkvs not to load, then the TV loses connection to the server
Please delete the file "LGST600.conf" from the renderers folder in your installation directory then run the program and try to connect with your TV. Then attach the debug.log here. That will give me information to see if we can improve support for your device.
Jaz808
Re: LG TV No DTS
Post by Jaz808 »
I have attached the log below
I made this from a bit of Editting, but not sure if it will damage anything, i did see a warning about not to edit files
Everything runs fine and its quick to load a movie, but still have the DTS problem
# LG TV
RendererName=LG 3D TV
UserAgentSearch=UPnP/1.0 DLNADOC/1.50
UserAgentAdditionalHeader=X-AV-Client-Info
Video=true
Audio=true
Image=true
SeekByTime=false
TranscodeVideo=MPEGTSAC3
TranscodeAudio=LPCM
DefaultVBVBufSize=true
MuxH264ToMpegTS=false
MuxDTSToMpeg=false
WrapDTSIntoPCM=flase
MuxLPCMToMpeg=false
MaxVideoBitrateMbps=0
MaxVideoWidth=1920
MaxVideoHeight=1080
H264Level41Limited=true
DLNALocalizationRequired=true
MediaParserV2_ThumbnailGeneration=false
ChunkedTransfer=true
MediaInfo=true
# [Supported video formats]:
Supported = f:mpegps|mpegts	v:mpeg1|mpeg2	 a:ac3|dts|lpcm|mpa|mp3				m:video/mpeg
Supported = f:mpegts		v:h264|vc1	 a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3	m:video/vnd.dlna.mpeg-tts
Supported = f:mp4|m4v		v:mp4|h264	 a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3	m:video/mpeg
Supported = f:avi|divx		v:divx|mp4	 a:ac3|lpcm|mpa|mp3				m:video/mpeg
Supported = f:mkv		v:mp4|divx|h264	 a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3	m:video/vnd.dlna.mpeg-tts
# [Supported audio formats]:
Supported = f:wma	n:2	m:audio/mpeg
Supported = f:mp3	n:2	m:audio/mpeg
Supported = f:lpcm 	n:2 	s:48000 m:audio/L16
# [Supported image formats]
Supported = f:jpg m:image/jpeg
debug.log
(17.89 KiB) Downloaded 883 times
Re: LG TV No DTS
You spelled "false" wrong in one of the DTS entries, I wonder if that is the problem?
By the way, can you tell me the exact model name of your TV?
Try this one:
LGTV.conf
(1.4 KiB) Downloaded 1033 times
Jaz808
Re: LG TV No DTS
Post by Jaz808 »
Its an Australian Model LG 55LW6500
3D Passive Cinema Range 2011,
still being sold in stores till April-May 2012, new model with Dual Screen View for 2 Player Games has just came out
Thx for picking up my spelling mistake, it might just be that, i will test tonight my time and report back
As being a newbie trying to understand these config file's, so sorry if this is a numb question,
Under [Supported video formats]: ..... Supported = f:mkv ......... v:mp4|divx|h264 ........ a:ac3|dts|dtshd|truehd|aac|lpcm|mpa|mp3
wouldn't anything to do with dts be taken out, or would it mean that MKV with dts would not be supported if taken out
I am still confused as i thought UMS transcoded DTS to AC3 if this was the case then i shoud Not have a problem, unless there is a setting i missed
Re: LG TV No DTS
Jaz808 wrote:i will test tonight my time and report back
Cool :D
Jaz808
Re: LG TV No DTS
Post by Jaz808 »
Thx SubJunk, tried your config/render but,
The LG TV still says "Unsupported Audio" for Mkv's with DTS
The TV shows the Audio as Unknown, Info from TV, File Format H.26 / Unknown / 1280x720
LG recommends "Plex Media Server" , as its a Smart Tv one of the Apps is called Media Link, and that talks to Plex and can play DTS
Maybe someone who knows what they are looking for can see how Plex does it
