No playable files in this folder - Philips TV
Hello!
I just got a Philips 49PUS6561 - Android TV and it has a SimplyShare option (DLNA).
Now I installed UMS and set it up (also put the share folders), but when I try to browse files on TV it finds my computer but every time I open it I get: No playable files in this folder.
I tried scanning my shared folders, add folder that has no sub folders (just a movie), turned off Kaspersky. Now I dont know what else there is.
I can access web UMS and watch movies like that on other PCs, so I guess UMS should be correctly configured.
Any help would be appreciated, thanks!
EDIT: I tried the VLC for Android TV and inside there it works, so I guess there is some problem with the TV conf
Re: No playable files in this folder - Philips TV
Post many times for the same issue is not the way to go:
viewtopic.php?f=5&t=9133
If we missed it, or we don't know, you should just post in your same original thread and it'll appear to us a new time.
And of course, make sure the issue was not already posted...
