UMS is showing on tv, but can't see any files (Philips 49PUS7909)
I have a Philips 49PUS7909/12 tv and can see the UMS in my sources but it doesn't show any files.
Also, I can start movies from my pc when I click on the tv and manually select a file, but I want to be able to select files on my tv.
Anybody who can help me?
Thanks!
Thanks!
Re: UMS is showing on tv, but can't see any files (Philips 49PUS7909)
Sure, if you help us to help you.
Just follow the forum rules write in red above your post
That's said, if you're lucky, it could be only be an incorrect firewall configuration. You can test it by disabling your firewall(s) and check if it solve your issue, and later re-configurate your firewall correctly.
If it didn't helped, your full trace log will be need.
ok
What is it at this address, 192.168.0.177, that keep sending SSDP search ?
I have no idea, doesn't show on my detected media renderers.
Set your IP filter in your GUI as following:
General Configuration tab ==> "Use an IP filter..." 192.168.0.114,192.168.0.157
Desactivate your TV server, as by default your TV act as a server and as a renderer.
Your TV is well know on the Emby forum to give this kind of issue.
Note: The next time, post only your log on a free and easy access website...like WeTranfer.com, Google Drive...
How do I deactivate my TV server?
I know for Panasonic but that's all.
I guess that you'll need to read your manual TV
Though it's not a garantie, just the first debubbing step.
