[Solved] Video skipping
Turbo Mach 5
Good lord, 5.1 on the 360. I am a happy man! Decided to give it a try on the 360. 5.1 seems to be working perfectly (as I was watching Afro Samurai Resurrection) but...ran into a slight problem that I don't know if honestly is caused by 3.0 a1 or something else so here goes: About 5-10 min into the movie, at the part where Afro gets his sword repaired and he sheathes it, the video freezes, skips, speeds up, then jumps back about a couple minutes before the error and repeats itself.
Here's the error from the debug log
If I have posted it in the wrong spot, I am sorry. I will also test this on the PS3 to see if it will do the same.
Other than that, keep up the good work! Looking forward to the power of 3.0!
DEBUG 2013-05-20 15:35:08.121 [Thread-25] Writing header...
DEBUG 2013-05-20 15:35:08.121 [Thread-25] INITV: 0.200, 0.158, fps: 23.976
DEBUG 2013-05-20 15:35:10.255 [Buffered IO End Checker] Stopping process: ffmpeg.exe-1
DEBUG 2013-05-20 15:35:10.810 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:10.924 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:11.691 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:12.536 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:12.650 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:13.282 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:13.365 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:13.438 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:13.543 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:13.657 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
INFO 2013-05-20 15:35:14.104 [StartPlaying Event] Started playing Afro Samurai Resurrection (720p).mkv on your Xbox 360
DEBUG 2013-05-20 15:35:14.104 [StartPlaying Event] The full filename of which is: F:\Movies and Episodes\Movies\Afro Samurai Resurrection (720p).mkv and the address of the renderer is: 192.168.1.103
DEBUG 2013-05-20 15:35:14.239 [New I/O worker #4] Setting InputStream new position to: 174,840
DEBUG 2013-05-20 15:35:15.192 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:15.311 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:16.552 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:16.634 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:16.716 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:16.761 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:16.900 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:35:42.782 [New I/O worker #6] Setting margin to 2Mb
DEBUG 2013-05-20 15:36:16.264 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-05-20 15:39:16.362 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-05-20 15:42:16.466 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-05-20 15:45:16.513 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-05-20 15:46:59.050 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:47:07.891 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:47:07.939 [Thread-24] [mpeg2video @ 01799fa0]rc buffer underflow
DEBUG 2013-05-20 15:48:16.599 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2013-05-20 15:51:16.637 [UPNP-AliveMessageSender] Sending ALIVE...Other than that, keep up the good work! Looking forward to the power of 3.0!
Re: Video skipping
Hi Turbo Mach 5, please do this viewtopic.php?f=9&t=556
Turbo Mach 5
Re: Video skipping
Oh kay did that, replayed video...did't happen...still got log
- (84.89 KiB) Downloaded 612 times
Re: Video skipping
Cool, well I suspect that what caused it to happen is UMS ran out of available RAM to use. It can happen sometimes and can usually be fixed by restarting the program or closing other programs that might be taking up that RAM
Turbo Mach 5
Re: Video skipping
Ahh ok (Was about to say strange I have 16GB of Ram but forgot how much Windows still allocates for applications). Thanks Sub!
