HELP, ISO files not working under UMS
MetalHead-666
Its been a while since I used UMS my pc it was running on crashed. So I did a re-install and downloaded java 8 and UMS like allways but I noticed with version 6.6.0 and also the new 7b2 I can browse thru my movie directory but when I select a folder containing a DVD ISO file, it displays the name, when I click it, it tells me no files to display. I know it had worked in the past. Anyone knows which version should work ? Secondly can this bug be solved?
