Renderer and Port Problem
ninjadudexp
So i keep wondering why i keep getting rendeerer not found, and test by test i got it. Everytime i turn off my computer or restart it the port that ums was using can no long be used for some reason, and then i you have to make it on another port. and to test it out i did it again. So what is the problem here?
Also even tho my xbox is showing up in ums, it is no longer finding videos on the xbox end of things which makes no sense now. and i would include a trace but nothing can be done in order to provide one that would be of some use
- Optimus_prime
Re: Renderer and Port Problem
Thanks for posting ninjadudexp, did you save your config by clicking save up the top after you changed your settings.
Could you also post a debug log anyway as it may shed some light, but most importantly it will give us an idea of what Type/Version of UMS your using. Instructions are here viewtopic.php?f=9&t=556
ninjadudexp
Ok i included the zip and everything, its working at the momment but like i said i have too keep switching ports (which are already open too) after each restart.
- (175.49 KiB) Downloaded 419 times
