UMS refuses to run media on PS4
Brutal1ty512
So, the problem I'm facing haunting me for quite some time. I have it since, I believe, ver. 5.5.0 or even earlier. For some reason, UMS periodically refuses to run my media on PS4 (wired connection) even if it was okay the day before. Then, even if I dont touch settings, it returns to normal again. Files that I used to create TRACE log had no promblem few days ago, then today i try to run them again and that's it, "cannot play media". The only connection i can make is that all my files use external "ass" subtitles. Media without them run perfectly.
- (2.19 MiB) Downloaded 535 times
Re: UMS refuses to run media on PS4
For now, you should use the UMS 6.5.3 version, as the others versions still have that bug.
Or you can replace your ffmpeg64.exe in your win32's UMS program file folder, by the one inside that 7z archive file (After having renamed it to ffmpeg64.exe).
Hoping that helped.
Hoping that helped.
