4k File not streaming
chuckau
Post by chuckau »
Hi Guys
I just got a 4k TV and the media server is working fine for my normal media but not working for my 4K movies.
I tested the files through USB and they work fine.
Any help would be great.
Thanks.
Logs
(98.3 KiB) Downloaded 425 times
Sami32
Re: 4k File not streaming
Post by Sami32 »
try with that renderer: (replace your renderer, found in your UMS "renderers" subfolder, by that one)
Sony-BraviaX.conf
(2.37 KiB) Downloaded 463 times
Please, don't forget to give feedback 8-)
chuckau
Post by chuckau »
Thanks for looking at this.
I added it and try and still didn't play the file. Attached is the new log
Sami32
Post by Sami32 »
Sorry, i miss your new log.
P.S. Don't forget to try with subtitles disabled as well (this option is in the "Transcoding Settings" tab)
If your issue still persist, update ffmpeg to the latest version.
Replace your ffmpeg64.exe file in your win32's UMS program subfolder, by the one inside this ZIP file (after having renamed to ffmpeg64.exe), and run a new test and attach your log here.
EDIT: I'll need you MediaInfo advanced log for this video: Fantastic Beasts and Where to Find Them 2016 Multi 2160p UHD BluRay HEVC HDR Atmos7.1-DDR.mkv
Go in the "Debug" menu and select "Advanced mode". Open that video file and post the log here (as a file or a copy paste)
chuckau
Post by chuckau »
Attached is Log
chuckau
Post by chuckau »
Movie.txt
(633.44 KiB) Downloaded 468 times
Sami32
Post by Sami32 »
Thank you 8-)
I still need your new UMS trace log with the new renderer that i given you.
chuckau
Post by chuckau »
(1.85 MiB) Downloaded 448 times
Sami32
Post by Sami32 »
Try with that beta version, add the renderer below, and post a new log:
https://we.tl/Y0YMTvXqD6
sample frequency:null
Sony-BraviaX.conf
(2.39 KiB) Downloaded 426 times
