Sony KDL-32WD756
Sony KDL-32WD756
Hi, my Sony sees UMS server, but when I try to connect to it and watch something, it says that it can't connect and I should check server settings.
Is there any way to fix it? Debug log in UMS server says nothing.
Re: Sony KDL-32WD756
Verify your firewall configuration and network settings.
Without your full trace log, as explained in the clickable red link in my signature below, not much can be done; so feel free to post your log if you need more help.
