Problem on Linux Mint 22.3
iamthebull
Re: Problem on Linux Mint 22.3
Post by iamthebull »
I installed valgrind and ran:
david@Desktop1:/opt/ums-15.6.0$ valgrind --leak-check=full --show-leak-kinds=all --verbose --log-file=/home/david/valgrind-out.txt ./UMS.sh
20:35:33,007 |-INFO in ch.qos.logback.classic.model.processor.ConfigurationModelHandlerFull - Scan attribute not set or set to unrecognized value.
20:35:33,008 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - About to instantiate property definer of type [net.pms.logging.DebugLogPropertyDefiner]
20:35:33,016 |-WARN in Logger[net.pms.configuration.UmsConfiguration] - No appenders present in context [default] for logger [net.pms.configuration.UmsConfiguration].
20:35:33,016 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - Setting property logFilePath=/home/david/.config/UMS in scope LOCAL
20:35:33,016 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - About to instantiate property definer of type [net.pms.logging.DebugLogPropertyDefiner]
20:35:33,016 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - Setting property rootLevel=DEBUG in scope LOCAL
20:35:33,016 |-INFO in ch.qos.logback.core.model.processor.DefineModelHandler - Setting property logFileName=debug.log in scope LOCAL
20:35:33,019 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - Processing appender named [traces]
20:35:33,019 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - About to instantiate appender of type [net.pms.logging.GuiManagerAppender]
20:35:33,043 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - Processing appender named [console]
20:35:33,043 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - About to instantiate appender of type [ch.qos.logback.core.ConsoleAppender]
20:35:33,044 |-INFO in ch.qos.logback.core.ConsoleAppender[console] - NOTE: Writing to the console can be slow. Try to avoid logging to the
20:35:33,044 |-INFO in ch.qos.logback.core.ConsoleAppender[console] - console in production environments, especially in high volume systems.
20:35:33,044 |-INFO in ch.qos.logback.core.ConsoleAppender[console] - See also https://logback.qos.ch/codes.html#slowConsole
20:35:33,044 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - Processing appender named [default.log]
20:35:33,044 |-INFO in ch.qos.logback.core.model.processor.AppenderModelHandler - About to instantiate appender of type [net.pms.logging.UmsFileAppender]
20:35:33,046 |-INFO in ch.qos.logback.core.model.processor.ModelInterpretationContext@3a7442c7 - value "/home/david/.config/UMS/debug.log" substituted for "${logFilePath}${file.separator}${logFileName}"
20:35:33,049 |-WARN in net.pms.logging.UmsFileAppender[default.log] - Append mode is mandatory for RollingFileAppender. Defaulting to append=true.
20:35:33,049 |-INFO in net.pms.logging.UmsFileAppender[default.log] - Active log file name: /home/david/.config/UMS/debug.log
20:35:33,049 |-INFO in net.pms.logging.UmsFileAppender[default.log] - File property is set to [/home/david/.config/UMS/debug.log]
20:35:33,050 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [org.apache] to WARN
20:35:33,050 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [httpclient.wire] to WARN
20:35:33,050 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [fm.last.musicbrainz.coverart] to WARN
20:35:33,050 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [oshi] to WARN
20:35:33,050 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [org.eclipse.jetty] to WARN
20:35:33,050 |-INFO in ch.qos.logback.classic.model.processor.LoggerModelHandler - Setting level of logger [com.zaxxer.hikari] to INFO
20:35:33,050 |-INFO in ch.qos.logback.core.model.processor.ModelInterpretationContext@3a7442c7 - value "DEBUG" substituted for "${rootLevel}"
20:35:33,050 |-INFO in ch.qos.logback.classic.model.processor.RootLoggerModelHandler - Setting level of ROOT logger to DEBUG
20:35:33,051 |-INFO in ch.qos.logback.core.model.processor.AppenderRefModelHandler - Attaching appender named [traces] to Logger[ROOT]
20:35:33,051 |-INFO in ch.qos.logback.core.model.processor.AppenderRefModelHandler - Attaching appender named [console] to Logger[ROOT]
20:35:33,051 |-INFO in ch.qos.logback.core.model.processor.AppenderRefModelHandler - Attaching appender named [default.log] to Logger[ROOT]
20:35:33,051 |-INFO in ch.qos.logback.core.model.processor.DefaultProcessor@4be29ed9 - End of configuration.
20:35:33,051 |-INFO in ch.qos.logback.classic.joran.JoranConfigurator@548d708a - Registering current configuration as safe fallback point
WARN  20:35:32.863 [main] Can't load neither /home/david/.config/UMS/UMS.conf: Unable to load the configuration from the URL file:/home/david/.config/UMS/UMS.conf nor /etc/skel/.config/UMS/UMS.conf: Unable to load the configuration from the URL file:/etc/skel/.config/UMS/UMS.conf
INFO  20:35:32.888 [main] Language not specified, defaulting to OS language.
ERROR 20:35:33.077 [main] Failed to write PID file: /home/david/.config/UMS/data/UMS.pid (No such file or directory)
INFO  20:35:33.222 [System Information Logger] System information:
  OS: GNU/Linux Linux Mint 22.3 (Zena) build 6.17.0-35-generic 64-bit
  JVM: OpenJDK 64-Bit Server VM 17.0.18 (64-bit) by BellSoft
  JVM args: -Xmx1280M -Xss2048k -Dfile.encoding=UTF-8 -Djava.net.preferIPv4Stack=true -Djna.nosys=true
  Language: English (United States)
  Encoding: UTF-8 | resolved UTF-8 | native UTF-8 | jnu UTF-8 | stdout UTF-8 | stderr UTF-8
  CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz with 4 cores (8 virtual cores) (Haswell (Client))
  Physical Memory: 15.5 GiB
  Free Memory: 11.5 GiB
  Maximum JVM Memory: 1.3 GiB
  Used network interfaces:
  Intel Corporation Ethernet Connection I217-V, speed 1000 Mb/s
INFO  20:35:37.760 [main] Starting Universal Media Server 15.6.0
INFO  20:35:37.760 [main] Based on PS3 Media Server by shagrath, copyright 2008-2014
INFO  20:35:37.760 [main] https://www.universalmediaserver.com
INFO  20:35:37.760 [main] Build: 806496f92 (2026-04-25)
INFO  20:35:37.761 [main] Working directory: /opt/ums-15.6.0
INFO  20:35:37.761 [main] Temporary directory: /tmp/UMS-david
INFO  20:35:37.761 [main] Logging configuration file: /opt/ums-15.6.0/logback.xml
INFO  20:35:37.761 [main] Logfile: /home/david/.config/UMS/debug.log
INFO  20:35:37.762 [main]
INFO  20:35:37.762 [main] Profile directory: /home/david/.config/UMS
INFO  20:35:37.762 [main] Profile directory permissions: drwx
INFO  20:35:37.762 [main] Profile configuration file: /home/david/.config/UMS/UMS.conf
INFO  20:35:37.763 [main] Profile configuration file permissions: -rw-
INFO  20:35:37.763 [main] Profile name: Desktop1
INFO  20:35:37.776 [main] Using database engine version 2.4.240
INFO  20:35:37.778 [main] Database may use 80 MB for caching
INFO  20:35:37.779 [main] Using "medias" database located at: "/home/david/.config/UMS/database"
INFO  20:35:37.787 [main] HikariPool-1 - Starting...
INFO  20:35:38.025 [main] HikariPool-1 - Added connection conn0: url=jdbc:h2:/home/david/.config/UMS/database/medias user=SA
INFO  20:35:38.026 [main] HikariPool-1 - Start completed.
INFO  20:35:38.083 [main] Creating database "medias" table: "TABLES_VERSIONS"
INFO  20:35:38.099 [main] Creating database "medias" table: "METADATA"
INFO  20:35:38.126 [main] Creating database "medias" table: "FILES"
INFO  20:35:38.147 [main] Creating database "medias" table: "VIDEO_METADATA"
INFO  20:35:38.164 [main] Creating database "medias" table: "VIDEOTRACKS"
INFO  20:35:38.177 [main] Creating database "medias" table: "SUBTRACKS"
INFO  20:35:38.186 [main] Creating database "medias" table: "CHAPTERS"
INFO  20:35:38.227 [main] Creating database "medias" table: "COVER_ART_ARCHIVE"
INFO  20:35:38.236 [main] Creating database "medias" table: "FILES_STATUS"
INFO  20:35:38.246 [main] Creating database "medias" table: "THUMBNAILS"
INFO  20:35:38.253 [main] Creating database "medias" table: "TV_SERIES"
INFO  20:35:38.259 [main] Creating database "medias" table: "FAILED_LOOKUPS"
INFO  20:35:38.264 [main] Creating database "medias" table: "VIDEO_METADATA_ACTORS"
INFO  20:35:38.273 [main] Creating database "medias" table: "VIDEO_METADATA_AWARDS"
INFO  20:35:38.286 [main] Creating database "medias" table: "VIDEO_METADATA_COUNTRIES"
INFO  20:35:38.293 [main] Creating database "medias" table: "VIDEO_METADATA_DIRECTORS"
INFO  20:35:38.304 [main] Creating database "medias" table: "VIDEO_METADATA_GENRES"
INFO  20:35:38.320 [main] Creating database "medias" table: "VIDEO_METADATA_RATINGS"
INFO  20:35:38.334 [main] Creating database "medias" table: "VIDEO_METADATA_LOCALIZED"
INFO  20:35:38.352 [main] Creating database "medias" table: "TV_SEASON_METADATA_LOCALIZED"
INFO  20:35:38.364 [main] Creating database "medias" table: "AUDIO_METADATA"
INFO  20:35:38.379 [main] Creating database "medias" table: "AUDIOTRACKS"
INFO  20:35:38.405 [main] Creating database "medias" table: "CONTAINER_FILES"
INFO  20:35:38.411 [main] Creating database "medias" table: "STORE_IDS"
INFO  20:35:38.433 [main] Using database engine version 2.4.240
INFO  20:35:38.437 [main] Database may use 80 MB for caching
INFO  20:35:38.437 [main] Using "USERS" database located at: "/home/david/.config/UMS/database"
INFO  20:35:38.438 [main] HikariPool-2 - Starting...
INFO  20:35:38.466 [main] HikariPool-2 - Added connection conn10: url=jdbc:h2:/home/david/.config/UMS/database/USERS user=SA
INFO  20:35:38.467 [main] HikariPool-2 - Start completed.
INFO  20:35:38.475 [main] Creating database "USERS" table: "TABLES_VERSIONS"
INFO  20:35:38.478 [main] Creating database "USERS" table: "GROUPS"
INFO  20:35:38.485 [main] Creating database "USERS" table: "USERS"
INFO  20:35:38.595 [main] Finding user id: -1
INFO  20:35:38.598 [main] Importing old shared content configuration files
INFO  20:35:40.611 [main] Configuration saved to "/home/david/.config/UMS/UMS.conf"
INFO  20:35:41.543 [main] Starting Jetty server 12.1.8
INFO  20:35:41.599 [main] GUI is available at: http://localhost:9001
INFO  20:35:41.602 [main] Starting Jetty server 12.1.8
INFO  20:35:41.619 [main] Finding user id: -1
INFO  20:35:41.624 [main] Loading renderer and device configurations from /opt/ums-15.6.0/renderers
INFO  20:35:41.976 [main] Enabled 217 configurations, listed in order of loading priority:
INFO  20:35:41.977 [main] :   Samsung 2021 AU8/AU7/BEA/32Q6
INFO  20:35:41.977 [main] :   LG TV 2025+
INFO  20:35:41.977 [main] :   Mirascreen
INFO  20:35:41.977 [main] :   Samsung 2021 AU9/Q6/43Q7/50Q7
INFO  20:35:41.977 [main] :   Samsung 2021+ NEO QLED TV 8K
INFO  20:35:41.977 [main] :   Sony Bravia XBR OLED
INFO  20:35:41.977 [main] :   Amazon Fire TV Stick Vimu Player
INFO  20:35:41.977 [main] :   BubbleUPnP
INFO  20:35:41.977 [main] :   Chromecast Ultra
INFO  20:35:41.977 [main] :   LG LCD TV (2014)
INFO  20:35:41.977 [main] :   LG LED-backlit LCD TV (2022+)
INFO  20:35:41.977 [main] :   LG LM660
INFO  20:35:41.977 [main] :   LG LS5700
INFO  20:35:41.977 [main] :   LG OLED
INFO  20:35:41.977 [main] :   LG OLED 2020/2021
INFO  20:35:41.977 [main] :   LG OLED 2022
INFO  20:35:41.978 [main] :   LG TV 2023+
INFO  20:35:41.978 [main] :   Naim Mu-So
INFO  20:35:41.978 [main] :   Panasonic AS600
INFO  20:35:41.978 [main] :   Panasonic AS650
INFO  20:35:41.978 [main] :   Panasonic BDT220
INFO  20:35:41.978 [main] :   Panasonic BDT360
INFO  20:35:41.978 [main] :   Panasonic CX680
INFO  20:35:41.978 [main] :   Panasonic CX700
INFO  20:35:41.978 [main] :   Panasonic DX
INFO  20:35:41.978 [main] :   Panasonic E6
INFO  20:35:41.978 [main] :   Panasonic ET60
INFO  20:35:41.978 [main] :   Panasonic GT50
INFO  20:35:41.978 [main] :   Panasonic GX800B
INFO  20:35:41.978 [main] :   Panasonic Home Theater (SC-BTT)
INFO  20:35:41.978 [main] :   Panasonic HZ1500
INFO  20:35:41.978 [main] :   Panasonic S60
INFO  20:35:41.978 [main] :   Panasonic ST60
INFO  20:35:41.979 [main] :   Panasonic VT60
INFO  20:35:41.979 [main] :   Philips 6500 Series TV
INFO  20:35:41.979 [main] :   Philips Android TV
INFO  20:35:41.979 [main] :   Samsung 2021 Q5
INFO  20:35:41.979 [main] :   Samsung 2021+ QLED TV
INFO  20:35:41.979 [main] :   Samsung EH5300
INFO  20:35:41.979 [main] :   Samsung Note Tab
INFO  20:35:41.979 [main] :   Samsung Q7 Series
INFO  20:35:41.979 [main] :   Samsung Soundbar MS750
INFO  20:35:41.979 [main] :   Skybox VR Player
INFO  20:35:41.979 [main] :   Sony Blu-ray (2013)
INFO  20:35:41.979 [main] :   Sony Bluray BDP-S3700
INFO  20:35:41.979 [main] :   Sony Bluray UBP-X800M2
INFO  20:35:41.979 [main] :   Sony Bravia EX
INFO  20:35:41.979 [main] :   Sony Bravia HX
INFO  20:35:41.979 [main] :   Sony Bravia W
INFO  20:35:41.979 [main] :   Sony Bravia X
INFO  20:35:41.979 [main] :   Sony Bravia XBR
INFO  20:35:41.979 [main] :   Sony Bravia XD/XE/XF
INFO  20:35:41.980 [main] :   Sony Bravia XH
INFO  20:35:41.980 [main] :   Sony Bravia XR
INFO  20:35:41.980 [main] :   Sony X Series TV
INFO  20:35:41.980 [main] :   VLC for Apple TV 4K
INFO  20:35:41.980 [main] :   VLC for iOS or macOS
INFO  20:35:41.980 [main] :   Xperia Z3
INFO  20:35:41.980 [main] :   Bigscreen
INFO  20:35:41.980 [main] :   Chromecast
INFO  20:35:41.980 [main] :   Denon AVR-4311CI
INFO  20:35:41.980 [main] :   Denon AVR-X4200W
INFO  20:35:41.980 [main] :   Hisense K680
INFO  20:35:41.980 [main] :   LG Blu-ray Player (BP550)
INFO  20:35:41.980 [main] :   LG EG910V
INFO  20:35:41.980 [main] :   LG LED-backlit LCD TV
INFO  20:35:41.980 [main] :   LG UB820V
INFO  20:35:41.980 [main] :   LG UH770
INFO  20:35:41.980 [main] :   LG WebOS TV
INFO  20:35:41.980 [main] :   Lumin U1 Mini
INFO  20:35:41.980 [main] :   Onkyo TX-NR8xx
INFO  20:35:41.980 [main] :   Panasonic DMR
INFO  20:35:41.980 [main] :   Panasonic TV
INFO  20:35:41.980 [main] :   Samsung 2018 QLED TV
INFO  20:35:41.981 [main] :   Samsung 5300 Series
INFO  20:35:41.981 [main] :   Samsung 8 Series
INFO  20:35:41.981 [main] :   Samsung 8K TV 2019+
INFO  20:35:41.981 [main] :   Samsung 9 Series
INFO  20:35:41.981 [main] :   Samsung BD-C6800
INFO  20:35:41.981 [main] :   Samsung D6400
INFO  20:35:41.981 [main] :   Samsung D7000
INFO  20:35:41.981 [main] :   Samsung EH6070
INFO  20:35:41.981 [main] :   Samsung ES6100
INFO  20:35:41.981 [main] :   Samsung ES6575
INFO  20:35:41.981 [main] :   Samsung ES8000
INFO  20:35:41.981 [main] :   Samsung ES8005
INFO  20:35:41.981 [main] :   Samsung F5100
INFO  20:35:41.981 [main] :   Samsung F5505
INFO  20:35:41.981 [main] :   Samsung F5900
INFO  20:35:41.981 [main] :   Samsung H4500
INFO  20:35:41.981 [main] :   Samsung H6203
INFO  20:35:41.981 [main] :   Samsung H6400
INFO  20:35:41.982 [main] :   Samsung H6500
INFO  20:35:41.982 [main] :   Samsung HT-E3 Series
INFO  20:35:41.982 [main] :   Samsung HT-F4
INFO  20:35:41.982 [main] :   Samsung J55xx Series
INFO  20:35:41.982 [main] :   Samsung J6200
INFO  20:35:41.982 [main] :   Samsung LED UHD
INFO  20:35:41.982 [main] :   Samsung PL51E490
INFO  20:35:41.982 [main] :   Samsung Q9 Series
INFO  20:35:41.982 [main] :   Samsung Soundbar
INFO  20:35:41.982 [main] :   Samsung The Frame
INFO  20:35:41.982 [main] :   Samsung UHD TV 2019+
INFO  20:35:41.982 [main] :   Sony Blu-ray
INFO  20:35:41.982 [main] :   Sony Bravia EX725
INFO  20:35:41.982 [main] :   Sony SA-NS310
INFO  20:35:41.982 [main] :   Vizio Smart TV
INFO  20:35:41.982 [main] :   VLC for Apple TV
INFO  20:35:41.983 [main] :   VLC for iOS (iPhone 5 or older)
INFO  20:35:41.983 [main] :   Xbox One
INFO  20:35:41.983 [main] :   Yamaha R-N303
INFO  20:35:41.983 [main] :   Yamaha R-N500
INFO  20:35:41.983 [main] :   Yamaha RX-A1010
INFO  20:35:41.983 [main] :   Yamaha RX-A2050
INFO  20:35:41.983 [main] :   Yamaha RX-V3900
INFO  20:35:41.983 [main] :   Yamaha RX-V500D
INFO  20:35:41.983 [main] :   Yamaha RX-V671
INFO  20:35:41.983 [main] :   AirPlayer
INFO  20:35:41.983 [main] :   Android
INFO  20:35:41.983 [main] :   AnyCast
INFO  20:35:41.983 [main] :   Apple iPad / iPhone
INFO  20:35:41.983 [main] :   Azur BD
INFO  20:35:41.984 [main] :   BRAVIA KDL-xxNX800
INFO  20:35:41.984 [main] :   Bush Freeview Set Top Box
INFO  20:35:41.984 [main] :   Caliber HPG336DAB/DIR
INFO  20:35:41.984 [main] :   D-Link DSM-510
INFO  20:35:41.984 [main] :   DirecTV
INFO  20:35:41.984 [main] :   Fetch TV
INFO  20:35:41.984 [main] :   foobar2000 mobile
INFO  20:35:41.984 [main] :   Freebox
INFO  20:35:41.984 [main] :   Freecom MusicPal
INFO  20:35:41.984 [main] :   Hama IR320
INFO  20:35:41.984 [main] :   KalemSoft Media Player
INFO  20:35:41.984 [main] :   Kodi
INFO  20:35:41.984 [main] :   LG Blu-ray Player (BDP)
INFO  20:35:41.984 [main] :   LG Blu-ray Player (BP)
INFO  20:35:41.984 [main] :   LG LA6200
INFO  20:35:41.984 [main] :   LG LA644V
INFO  20:35:41.984 [main] :   LG LM620
INFO  20:35:41.985 [main] :   LG NANO TV
INFO  20:35:41.985 [main] :   LG Smart TV Upgrader
INFO  20:35:41.985 [main] :   Linn App (control point)
INFO  20:35:41.985 [main] :   Logitech Squeezebox
INFO  20:35:41.985 [main] :   Lumin
INFO  20:35:41.985 [main] :   MediaPlayer
INFO  20:35:41.985 [main] :   Miracast M806
INFO  20:35:41.985 [main] :   Movian
INFO  20:35:41.985 [main] :   Naim Mu-So Qb
INFO  20:35:41.985 [main] :   Netgear NeoTV
INFO  20:35:41.985 [main] :   Netgem N7700
INFO  20:35:41.985 [main] :   NextCP2
INFO  20:35:41.985 [main] :   Nokia N900
INFO  20:35:41.985 [main] :   Onkyo TX-NR7xx
INFO  20:35:41.985 [main] :   OPPO BDP
INFO  20:35:41.985 [main] :   OPPO BDP-83
INFO  20:35:41.985 [main] :   Panasonic BDT
INFO  20:35:41.985 [main] :   Panasonic TX-L32V10E
INFO  20:35:41.985 [main] :   Panasonic U30Z
INFO  20:35:41.985 [main] :   Philips Aurea
INFO  20:35:41.985 [main] :   Philips PUS TV
INFO  20:35:41.986 [main] :   Philips TV
INFO  20:35:41.986 [main] :   Pigasus
INFO  20:35:41.986 [main] :   Pioneer BDP
INFO  20:35:41.986 [main] :   Pioneer Kuro
INFO  20:35:41.986 [main] :   PlayStation 3
INFO  20:35:41.986 [main] :   PlayStation 4
INFO  20:35:41.986 [main] :   PlayStation Vita
INFO  20:35:41.986 [main] :   Popcorn Hour
INFO  20:35:41.986 [main] :   Realtek
INFO  20:35:41.986 [main] :   Roku (DVP 10)
INFO  20:35:41.986 [main] :   Roku 3 (NSP 3)
INFO  20:35:41.986 [main] :   Roku 3 (NSP 5)
INFO  20:35:41.986 [main] :   Roku 3 (NSP 6-7)
INFO  20:35:41.986 [main] :   Roku 4 (NSP 6-7)
INFO  20:35:41.986 [main] :   Roku TV
INFO  20:35:41.986 [main] :   Roku TV (NSP 8)
INFO  20:35:41.986 [main] :   Roku TV 4K
INFO  20:35:41.986 [main] :   Roku Ultra
INFO  20:35:41.986 [main] :   Samsung C/D Series
INFO  20:35:41.986 [main] :   Samsung C6600
INFO  20:35:41.986 [main] :   Samsung E+ Series
INFO  20:35:41.986 [main] :   Samsung Galaxy S5
INFO  20:35:41.986 [main] :   Samsung Galaxy S7
INFO  20:35:41.986 [main] :   Samsung Mobile
INFO  20:35:41.987 [main] :   Samsung OLED
INFO  20:35:41.987 [main] :   Samsung SMT-G7400
INFO  20:35:41.987 [main] :   Samsung WiseLink
INFO  20:35:41.987 [main] :   Sharp Aquos
INFO  20:35:41.987 [main] :   Showtime 3
INFO  20:35:41.987 [main] :   Showtime 4
INFO  20:35:41.987 [main] :   Sony Bravia
INFO  20:35:41.987 [main] :   Sony Bravia 4500
INFO  20:35:41.987 [main] :   Sony Bravia 5500
INFO  20:35:41.987 [main] :   Sony Bravia AG
INFO  20:35:41.987 [main] :   Sony Bravia BX305
INFO  20:35:41.987 [main] :   Sony Bravia EX620
INFO  20:35:41.987 [main] :   Sony Bravia HX75
INFO  20:35:41.987 [main] :   Sony Bravia NX70x
INFO  20:35:41.987 [main] :   Sony Home Theatre System
INFO  20:35:41.987 [main] :   Sony SMP-N100
INFO  20:35:41.987 [main] :   Sony STR-DA5800ES
INFO  20:35:41.987 [main] :   Sony STR-DN1080
INFO  20:35:41.987 [main] :   Sony Xperia Z/ZL/ZQ/Z1/Z2
INFO  20:35:41.987 [main] :   Streamium
INFO  20:35:41.987 [main] :   Technisat S1+
INFO  20:35:41.987 [main] :   Telefunken TV
INFO  20:35:41.987 [main] :   Telstra T-Box
INFO  20:35:41.987 [main] :   Thomson U3 Series
INFO  20:35:41.987 [main] :   UnknownRenderer
INFO  20:35:41.987 [main] :   VideoWeb TV
INFO  20:35:41.987 [main] :   VLC for desktop
INFO  20:35:41.987 [main] :   WD TV Live
INFO  20:35:41.987 [main] :   WiiM
INFO  20:35:41.987 [main] :   Windows Media Player
INFO  20:35:41.987 [main] :   XBMC
INFO  20:35:41.988 [main] :   Xbox 360
INFO  20:35:41.988 [main] :   Yamaha AV Receiver
INFO  20:35:41.988 [main] Checking the fontconfig cache in the background, this can take two minutes or so.
INFO  20:35:42.019 [main] Configuration saved to "/home/david/.config/UMS/UMS.conf"
INFO  20:35:42.060 [main] Transcoding engine "FFmpeg Audio" is available
INFO  20:35:42.175 [main] Transcoding engine "MEncoder Video" is available
INFO  20:35:42.176 [main] Transcoding engine "FFmpeg Video" is available
INFO  20:35:42.182 [main] Transcoding engine "VLC Video" is available
INFO  20:35:42.183 [main] Transcoding engine "FFmpeg HLS Video" is available
INFO  20:35:42.183 [main] Transcoding engine "FFmpeg Web Video" is available
INFO  20:35:42.184 [main] Transcoding engine "MEncoder Web Video" is available
INFO  20:35:42.184 [main] Transcoding engine "VLC Web Video" is available
INFO  20:35:42.187 [main] Transcoding engine "tsMuxeR Video" is available
INFO  20:35:42.188 [main] Transcoding engine "tsMuxeR Audio" is available
INFO  20:35:42.189 [main] Transcoding engine "VLC Web Audio (Legacy)" is available
INFO  20:35:42.189 [main] Transcoding engine "VLC Web Video (Legacy)" is available
INFO  20:35:42.195 [main] Transcoding engine "DCRaw" is available
INFO  20:35:42.195 [main] Transcoding engine "youtube-dl" is available
INFO  20:35:42.476 [main] Generated new random UUID: ad0b1773-fcb2-4f1e-b1d3-9d561c5e25da
INFO  20:35:42.478 [main] Configuration saved to "/home/david/.config/UMS/UMS.conf"
INFO  20:35:42.478 [main] Using the following UUID configured in UMS.conf: ad0b1773-fcb2-4f1e-b1d3-9d561c5e25da
INFO  20:35:42.564 [main] Starting UPnP service...
INFO  20:35:42.594 [main] Registering UPnP servlet under context path:
INFO  20:35:42.603 [jupnp-stream-server 5-1] Starting Jetty server 12.1.8
INFO  20:35:42.621 [main] Starting Jetty HTTP client v12.1.8 connection manager/pool
INFO  20:35:42.661 [jupnp-multicast-receiver 3-1] IP Filter: Access allowed to 10.0.1.2
INFO  20:35:43.127 [main] Web player is available at: http://10.0.1.2:9002
INFO  20:35:44.148 [Web GUI browser] Launching the graphical interface on a browser
INFO  20:35:44.149 [main] Universal Media Server is now available for renderers to find
INFO  20:35:44.150 [Media Scanner] Media scan started
INFO  20:35:44.262 [Media Scanner] Loading MediaInfo library
INFO  20:35:44.292 [Media Scanner] Loaded MediaInfoLib - v24.01
INFO  20:35:44.785 [Media Scanner] Media scan completed in 0 seconds
INFO  20:35:44.790 [Media Scanner] Database analyze started
INFO  20:35:44.793 [Media Scanner] Database analyze completed in 0 seconds
WARN  20:35:54.395 [webgui-server-169] Error verifying JWT: The Token's Signature resulted invalid when verified using the Algorithm: HmacSHA256
WARN  20:35:54.395 [webgui-server-53] Error verifying JWT: The Token's Signature resulted invalid when verified using the Algorithm: HmacSHA256
WARN  20:35:54.395 [webgui-server-59] Error verifying JWT: The Token's Signature resulted invalid when verified using the Algorithm: HmacSHA256
WARN  20:35:54.395 [webgui-server-55] Error verifying JWT: The Token's Signature resulted invalid when verified using the Algorithm: HmacSHA256
INFO  20:35:54.395 [webgui-server-53] Checking user table have admin
INFO  20:35:54.395 [webgui-server-59] Checking user table have admin
WARN  20:35:54.397 [webgui-server-55] Error verifying JWT: The Token's Signature resulted invalid when verified using the Algorithm: HmacSHA256
INFO  20:35:54.398 [webgui-server-169] Checking user table have admin
WARN  20:35:54.399 [webgui-server-54] Error verifying JWT: The Token's Signature resulted invalid when verified using the Algorithm: HmacSHA256
INFO  20:36:00.780 [webgui-server-168] Checking user table have admin
INFO  20:36:00.781 [webgui-server-168] Creating user: asdf
INFO  20:36:01.182 [webgui-server-168] Creating user: asdf
INFO  20:36:01.183 [webgui-server-168] Created user successfully in USERS
INFO  20:36:01.183 [webgui-server-168] Finding user: asdf
INFO  20:36:01.454 [webgui-server-168] User asdf logged
WARN  20:36:01.472 [webgui-server-59] Error verifying JWT: The Token's Signature resulted invalid when verified using the Algorithm: HmacSHA256
INFO  20:36:01.472 [webgui-server-59] Checking user table have admin
INFO  20:36:01.550 [webgui-server-58] Listing all users
INFO  20:36:20.289 [Media Scanner] Media scan started
malloc(): invalid size (unsorted)
Aborted (core dumped)
valgrind-out.txt - I have no idea how to interpret any of this...
==24351== Memcheck, a memory error detector
==24351== Copyright (C) 2002-2022, and GNU GPL'd, by Julian Seward et al.
==24351== Using Valgrind-3.22.0-bd4db67b1d-20231031 and LibVEX; rerun with -h for copyright info
==24351== Command: ./UMS.sh
==24351== Parent PID: 2998
==24351==
--24351--
--24351-- Valgrind options:
--24351--    --leak-check=full
--24351--    --show-leak-kinds=all
--24351--    --verbose
--24351--    --log-file=/home/david/valgrind-out.txt
--24351-- Contents of /proc/version:
--24351--   Linux version 6.17.0-35-generic (buildd@lcy02-amd64-079) (x86_64-linux-gnu-gcc-13 (Ubuntu 13.3.0-6ubuntu2~24.04.1) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #35~24.04.1-Ubuntu SMP PREEMPT_DYNAMIC Tue May 26 19:30:42 UTC 2
--24351--
--24351-- Arch and hwcaps: AMD64, LittleEndian, amd64-cx16-lzcnt-rdtscp-sse3-ssse3-avx-avx2-bmi-f16c-rdrand
--24351-- Page sizes: currently 4096, max supported 4096
--24351-- Valgrind library directory: /usr/libexec/valgrind
--24351-- Reading syms from /usr/bin/dash
--24351-- Reading syms from /usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2
--24351--   Considering /usr/lib/debug/.build-id/da/07864eb4c1b06504b8688d25d7e84759fe708d.debug ..
--24351--   .. build-id is valid
--24351-- Reading syms from /usr/libexec/valgrind/memcheck-amd64-linux
--24351--    object doesn't have a dynamic symbol table
--24351-- Scheduler: using generic scheduler lock implementation.
--24351-- Reading suppressions file: /usr/libexec/valgrind/default.supp
==24351== embedded gdbserver: reading from /tmp/vgdb-pipe-from-vgdb-to-24351-by-david-on-???
==24351== embedded gdbserver: writing to   /tmp/vgdb-pipe-to-vgdb-from-24351-by-david-on-???
==24351== embedded gdbserver: shared mem   /tmp/vgdb-pipe-shared-mem-vgdb-24351-by-david-on-???
==24351==
==24351== TO CONTROL THIS PROCESS USING vgdb (which you probably
==24351== don't want to do, unless you know exactly what you're doing,
==24351== or are doing some strange experiment):
==24351==   /usr/bin/vgdb --pid=24351 ...command...
==24351==
==24351== TO DEBUG THIS PROCESS USING GDB: start GDB like this
==24351==   /path/to/gdb ./UMS.sh
==24351== and then give GDB the following command
==24351==   target remote | /usr/bin/vgdb --pid=24351
==24351== --pid is optional if only one valgrind process is running
==24351==
--24351-- REDIR: 0x4028b00 (ld-linux-x86-64.so.2:strlen) redirected to 0x580c2e1a (???)
--24351-- REDIR: 0x40272b0 (ld-linux-x86-64.so.2:index) redirected to 0x580c2e34 (???)
--24351-- Reading syms from /usr/libexec/valgrind/vgpreload_core-amd64-linux.so
--24351-- Reading syms from /usr/libexec/valgrind/vgpreload_memcheck-amd64-linux.so
==24351== WARNING: new redirection conflicts with existing -- ignoring it
--24351--     old: 0x04028b00 (strlen              ) R-> (0000.0) 0x580c2e1a ???
--24351--     new: 0x04028b00 (strlen              ) R-> (2007.0) 0x0484f340 strlen
--24351-- REDIR: 0x40274e0 (ld-linux-x86-64.so.2:strcmp) redirected to 0x4850460 (strcmp)
--24351-- REDIR: 0x4026910 (ld-linux-x86-64.so.2:mempcpy) redirected to 0x4853cd0 (mempcpy)
--24351-- Reading syms from /usr/lib/x86_64-linux-gnu/libc.so.6
--24351--   Considering /usr/lib/debug/.build-id/8e/9fd827446c24067541ac5390e6f527fb5947bb.debug ..
--24351-- REDIR: 0x4028ca0 (ld-linux-x86-64.so.2:strncmp) redirected to 0x484fc90 (strncmp)
--24351-- REDIR: 0x4922070 (libc.so.6:strnlen) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4922100 (libc.so.6:strpbrk) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x49201c0 (libc.so.6:strcmp) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x49393b0 (libc.so.6:wcsnlen) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x491f2b0 (libc.so.6:memset) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4938b20 (libc.so.6:wcslen) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x49a43f0 (libc.so.6:__memcpy_chk) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x491f220 (libc.so.6:memrchr) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4939350 (libc.so.6:wcsncpy) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x491e740 (libc.so.6:memcpy@@GLIBC_2.14) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x49378e0 (libc.so.6:wcschr) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x49200b0 (libc.so.6:index) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4922130 (libc.so.6:rindex) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4937990 (libc.so.6:wcscmp) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x491f4d0 (libc.so.6:stpncpy) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4945eb0 (libc.so.6:wmemchr) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4921f10 (libc.so.6:strncmp) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x491f530 (libc.so.6:strcasecmp) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4921330 (libc.so.6:strcspn) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x49388f0 (libc.so.6:wcscpy) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4920040 (libc.so.6:strcat) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4921e10 (libc.so.6:strncasecmp_l) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4920130 (libc.so.6:strchrnul) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x491e650 (libc.so.6:bcmp) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x49212c0 (libc.so.6:strcpy) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x491f5d0 (libc.so.6:strcasecmp_l) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4921ce0 (libc.so.6:strlen) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4921fb0 (libc.so.6:strncpy) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4945f30 (libc.so.6:wmemcmp) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x49a4510 (libc.so.6:__memmove_chk) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351--     old: 0x049f5a50 (__memcpy_chk_avx_una) R-> (2030.0) 0x04853dd0 __memcpy_chk
--24351--     new: 0x049f5a50 (__memcpy_chk_avx_una) R-> (2024.0) 0x04853740 __memmove_chk
--24351-- REDIR: 0x491f460 (libc.so.6:stpcpy) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x491efe0 (libc.so.6:memmove) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
==24351== Preferring higher priority redirection:
--24351--     old: 0x049f5a80 (__memcpy_avx_unalign) R-> (2018.0) 0x04851580 __memcpy_avx_unaligned_erms
--24351--     new: 0x049f5a80 (__memcpy_avx_unalign) R-> (2018.1) 0x04852d60 memmove
--24351-- REDIR: 0x491e5d0 (libc.so.6:memchr) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4922300 (libc.so.6:strspn) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x491f100 (libc.so.6:mempcpy) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4921d70 (libc.so.6:strncasecmp) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x4922bc0 (libc.so.6:strstr) redirected to 0x483d1c0 (_vgnU_ifunc_wrapper)
--24351-- REDIR: 0x49fa670 (libc.so.6:__strrchr_avx2) redirected to 0x484ed20 (rindex)
--24351-- REDIR: 0x491a670 (libc.so.6:malloc) redirected to 0x48467b0 (malloc)
--24351-- REDIR: 0x49f7e20 (libc.so.6:__strchrnul_avx2) redirected to 0x48537b0 (strchrnul)
--24351-- REDIR: 0x49f7be0 (libc.so.6:__strchr_avx2) redirected to 0x484ef00 (index)
--24351-- REDIR: 0x49f5a80 (libc.so.6:__memcpy_avx_unaligned_erms) redirected to 0x4852d60 (memmove)
--24351-- REDIR: 0x49f87c0 (libc.so.6:__strlen_avx2) redirected to 0x484f220 (strlen)
--24351-- REDIR: 0x49f5a50 (libc.so.6:__memcpy_chk_avx_unaligned_erms) redirected to 0x4853dd0 (__memcpy_chk)
--24351-- REDIR: 0x49f5a40 (libc.so.6:__mempcpy_avx_unaligned_erms) redirected to 0x48538d0 (mempcpy)
--24351-- REDIR: 0x49f8010 (libc.so.6:__strcmp_avx2) redirected to 0x4850360 (strcmp)
--24351-- REDIR: 0x491ad50 (libc.so.6:free) redirected to 0x4849820 (free)
--24351-- REDIR: 0x4a14ff0 (libc.so.6:__strcspn_sse42) redirected to 0x4854010 (strcspn)
--24351-- REDIR: 0x491b0c0 (libc.so.6:realloc) redirected to 0x484db00 (realloc)
--24359-- REDIR: 0x4a17b90 (libc.so.6:__strpbrk_sse42) redirected to 0x4853fc0 (strpbrk)
--24359-- REDIR: 0x49f8570 (libc.so.6:__strcpy_avx2) redirected to 0x484f370 (strcpy)
--24359-- REDIR: 0x49a4fc0 (libc.so.6:__strcpy_chk) redirected to 0x4853830 (__strcpy_chk)
--24360-- REDIR: 0x4a17b90 (libc.so.6:__strpbrk_sse42) redirected to 0x4853fc0 (strpbrk)
--24360-- REDIR: 0x49f8570 (libc.so.6:__strcpy_avx2) redirected to 0x484f370 (strcpy)
--24360-- REDIR: 0x49a4fc0 (libc.so.6:__strcpy_chk) redirected to 0x4853830 (__strcpy_chk)
--24361-- REDIR: 0x4a17b90 (libc.so.6:__strpbrk_sse42) redirected to 0x4853fc0 (strpbrk)
--24361-- REDIR: 0x49f8570 (libc.so.6:__strcpy_avx2) redirected to 0x484f370 (strcpy)
--24361-- REDIR: 0x49a4fc0 (libc.so.6:__strcpy_chk) redirected to 0x4853830 (__strcpy_chk)
--24351-- REDIR: 0x4a17b90 (libc.so.6:__strpbrk_sse42) redirected to 0x4853fc0 (strpbrk)
--24351-- REDIR: 0x49a4fc0 (libc.so.6:__strcpy_chk) redirected to 0x4853830 (__strcpy_chk)
--24351-- REDIR: 0x4a17c90 (libc.so.6:__strspn_sse42) redirected to 0x4854110 (strspn)
boss
Post by boss »
I installed and ran valgrind on my system. It ran without any errors or warnings.
The output from your test had:
And
I think this the cause of the issue. I have no idea what is causing it though.
It would seem that UMS is trying to write to some memory space which is already occupied.
But then is not allocating a different memory space but ignoring it.
iamthebull wrote: ↑Wed Jul 01, 2026 1:33 pm mik_s wrote: ↑Tue Jun 30, 2026 10:23 pm
Did you try the ram tests using only 1 stick instead of in pairs.
No. With only 1 stick of RAM I was wondering if we would maybe run into memory issues due to the OS not having so much memory (only 4GB). So I stuck with pairs and mixed them up enough to be thorough. I would think if there was a hardware issue with the RAM it would have shown up by now. And there would be RAM issues with other programs. Which there isn't.
It should be fine on only 1 stick of 4GB. Windows worked for me on 4GB when one of mine failed. It was very slow but just usable
Linux does not have the bloat Windows has so should handle it better.
I'm thinking with all the read access to do with scanning a large amount of small MP3 files rapidly may be a factor.
I've been thinking about that also but from the perspective of maybe we don't get the malloc error on the Mint 22.3 install on the laptop because it's reading the Music folder over the network which is significantly slower.
All of the database writes would be local so it should not matter if it is over the network.
Do you have space on the laptop to copy your MP3s to it, or even connect the media drive to it so they local when scanning?
iamthebull wrote: ↑Wed Jul 01, 2026 1:33 pm The OS (Mint 22.3) is running on an SSD - INTEL SSDSC2BW240A4 (DC02) and the media files (Music folder) is on a HDD - WDC WD20EFRX-68EUZN0 (80.00A80) on the same PC.
That is quite an old SSD (10-13 years) so it may be starting to fail. It will also depend on how full it is and the amount of wear.
I have been looking to see what software is available for it but Intel have dropped support for it so no longer have it available (there may have been some security flaws too) plus it is only on Windows.
I just saw a video about Xbox repair where the new SSD failed and they used a program called CrystalDiskInfo to check the SMART report on the drive.
I checked to see if that is available on Linux but its not.
I think a similar alternative is smartctl and GSmartControl for the GUI. I got that from this old reddit post so there may be something better now.
It is also mentioned on the Mint forum here.
iamthebull
Hard disks
On the desktop
I copied the Music folder to a different physical HDD and scanned - malloc error
I copied the Music folder to a different physical SDD and scanned - malloc error
This suggests it's not a hardware issue with the hard disks
On the laptop (Mint 22.3)
I copied the Music folder to a local SDD and scanned - no errors
Memory
I did a memory scan overnight - 10 passes no errors
I also tested each memory stick individually and all 4 tests resulted in malloc error
I think it's safe to say now that there are no problems with the RAM itself.
I think it might be time now to explore the option that this may, in fact, be a programming issue and get the developers involved. What is the procedure there?
boss
Post by boss »
I think you have done everything you can.
My best guess is this is what is happening.
UMS is trying to write to a part of your memory which is normally free but in your case is being used. Any part/item of the hardware on your computer could be using that memory space.
In the valgrind test there is this:
And
Perhaps the "ignoring it" part is the problem. Perhaps UMS code needs to be changed so if this happens instead of ignoring it, UMS tries a different memory allocation.
I am just guessing here though.
@mik_s could advise how to get the developers involved.
Good luck.
Did you try another boot drive on the desktop though as that is the only other thing I can think of.
The drive the music is on should not be causing it as it is only being read. The database is on the system drive and that is still the common factor.
Could you put a fresh install of Mint on a spare drive or USB stick and boot from that and install UMS?
If that does not have malloc errors then it does narrow it down to your SSD boot drive, whether hardware issue or something in that OS install.
Try running those drive programs to check the SMART report of the drives, especially the OS SSD for the desktop.
Besides that I have no idea what else to check. I could open an issue on Github so the devs can see and may have better insight on what to look for.
iamthebull
I booted Mint 22.3 using a Live USB and installed UMS-15.6.0 then scanned Music folder and got the malloc error. That should rule out my OS SSD.
iamthebull
I opened an issue on github and the developers seem disinterested in addressing this issue.
