[Solved] Bad subtitle language detection
Since version 5.1.4, french subtitles appear as romanian subtitles on the TV via HDMI to PS3.
When using the "TRANSCODE" function, a romanian flag stands on the left of the subtitle name.
Although the subtitles are really french, their appear on the TV screen with special characters (which I suppose are romanian ...).
If someone can help ...
By the way, thanks so much for UMS software !!!
Cheers from France.
Cheers from France.
- (11.31 KiB) Downloaded 554 times
Re: Bad subtitle language detection
Can you send here an example of the bad recognized subtitles file for testing?
Thank you valib !
Here is a bad recognized subtitles file ...
- Once.Upon.a.Time.S01E01.720p.HDTV.X264-DIMENSION.srt.zip
- (16.04 KiB) Downloaded 652 times
So did someone reproduce the bug ?
Thank you .
Thank you .
Sorry for the delay I was a little bit busy. I reproduced that bug. There is a problem with the codepage detection. UMS uses third party solution but the detection is not working 100%. You can solve it eider by converting of your subtitles to the UTF-8 code page or set the "Codepage for non_Unicode subtitles" at the "Transcoding setting", "Subtitles settings" to the CP1252 or ISO-8859-1.
Thank you valib !
I set the "Codepage for non_Unicode subtitles" at the "Transcoding setting", "Subtitles settings" to CP1252, and although the subtitle flag is still romanian, there are no more romanaion special characters.
So I can use 5.2.2 version !!!
Thanks again
Thanks again
No more romanian flag next to french subtitles with 5.2.3.
Thanks guys
Thanks guys
Thanks for the info. Can you try to set "Subtitles settings" back to empty and check if your subs are correctly recognized?chrisl wrote:No more romanian flag next to french subtitles with 5.2.3.
Thanks guys
I just did it, and it is OK.
No more romanian special characters, just french ...
All is ok now, problem solved
Thanks again !
Thanks again !
